Sponsored by: Real Truck
Ignition switch ?
Old Dec 2, 2006 | 06:31 PM
dsmolj's Avatar
dsmolj
Ignition switch ?
My 2000 S/D with not start sometimes unless I giggle the transmisssion shifter, I'm asuming the ignition sw is bad, how difficult is this to replace ?
Old Dec 2, 2006 | 06:46 PM
roush69's Avatar
roush69
is your shifter loose at the colum
Old Dec 2, 2006 | 07:06 PM
dkstuck's Avatar
dkstuck
Sounds more like nuetral safety switch needa adjusted. Not sure how to adjust your model.
Old Dec 2, 2006 | 07:17 PM
dsmolj's Avatar
dsmolj
No at least I don't think so, when I worked for GM years ago chevy's was a rod that came down the steering column and pinned into the neutral safety / ignition sw I'm assuming ford is probably similar
Old Dec 3, 2006 | 05:21 PM
dsmolj's Avatar
dsmolj
that what I was thinking also I'm sure it can't be to difficult
Old Dec 4, 2006 | 08:36 PM
ohboy44's Avatar
ohboy44
The neutral saftey switch in on the trans, it's adjustable by loosening the 2 bolts. But before I did that I would check for play in the shifter cable or a worn out shifter cable.
Old Dec 4, 2006 | 08:45 PM
PHWLEE's Avatar
PHWLEE
I was just under the dash the other day wiring my airhorn and noticed a kind of switch looking thing that had the capability of being loosened ot tightened. It may be the neutral safety because it had the stopper that could be adjusted and the metal rod that went beyond where I could see. Might be worth taking a look. Just open the fuse box access panel at the knee strike and take a look up you'll see it running along the column. Don't want to make you go on a wild goose chase, but I figured it couldn't hurt mentioning.
cts1954
Mar 11, 2013 03:01 PM
ahurt1973
Oct 25, 2006 02:52 PM
novadragman2005
30
Feb 16, 2005 03:20 PM
mitchw32
Jan 31, 2005 08:21 PM
Gus44
Jan 1, 2003 07:09 PM
