f250 died while driving
Old Dec 6, 2006 | 08:24 PM
clux's Avatar
clux
Sure, it's possible, people have fried their pcm simply installing or removing chips with the battery connected. I think it's a good sign that your engine is running well when it runs, though.
Old Dec 6, 2006 | 08:49 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
damn it, you never know what you can screw up just installing mirrors
but i have my hopes that it might be just that ground connection or that power wire, otherwise im in for a new PCM, what a ball,
Old Dec 6, 2006 | 11:37 PM
ryaneverk2's Avatar
ryaneverk2
Pete, will it start at all right now?
If not, when you turn the key to RUN, does the WTS light come on as it should?
If it does, that would indicate to me that the PCM is good. If it doesn't, then the PCM or one of its fuses are probably bad.
Old Dec 6, 2006 | 11:53 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Yeah Pete, lotta indicators there. WTS light, fuel pump running, power to GPR etc. If this is happening, your PCM is likely fine. These are commanded on by the PCM, not the ignition switch, well in conjunction with it, but by the PCM.
Old Dec 7, 2006 | 02:34 PM
PETE'S_6.0PSD
yeah guys , i get all as normal, nothing diferent, just like i would turn the key off, or maybe more like ran out of fuel, but its starts right away without cranking it over for to long, just normal start,,,ill check the wires now, and ill post back , ill be driving it shopping later, and ill see if it happens again
Old Dec 7, 2006 | 02:56 PM
PETE'S_6.0PSD
ok another thing is, i just nipped the power cables to my mirrors to make sure this is not causing a problem and i did change the ground to a diferent spot, , can you guys tell me where would be a good place where i can tap in to for heated mirrors? so i dont overload somthing,
ill post back from my trip later on,
thanks for the help guys
im glad that i have place to go back to to get my problems taken care of
no the stellarship !!!!
Old Dec 7, 2006 | 06:50 PM
PETE'S_6.0PSD
still nothing, i changed ground position, and took off my power to the mirrors,
left the house and within 1 mile DIED 3 times, no SES light nothing , just battery light, than just turn the key and bia$%#^ starts right up
i dont know anymore
just put the fresh fuel with aditive and died when i got home on my driveway
still starts right up
damn thing
i love the truck but its starting to scare me
please help guys
Old Dec 7, 2006 | 07:12 PM
Uzumati's Avatar
Uzumati
Sounds kinda like someting is causing a current drain or ground loop and the pcm is reseting. Do you have a way to monitor PCM voltage while running?
Old Dec 7, 2006 | 07:19 PM
PETE'S_6.0PSD
i can , where should i monitor it?
and what should i look for,
this whole thing started right after i did my mirrors
damn it
maybe i should just completly disconect them and see what happens?
its driving me crazy
Old Dec 7, 2006 | 07:24 PM
Uzumati's Avatar
Uzumati
fuse 24 under the hood feeds the pcm power relay
If you have not completely disconnected them I would try that first since this is when it all started
Old Dec 16, 2006 | 03:11 PM
PETE'S_6.0PSD
ok its fixed, my F5 chip cable was causing it, it was getting interferences from the power cables or whatever was around it, put the shield over it ground it to chasis and done, i has been a good baby now,
thank Good
i hope Jody will ship out upgraded cables before anyone will get hurt, when he truck dies in a bad moment,,,
Old Dec 16, 2006 | 03:14 PM
Tenn01PSD350
Hmmmm, another ribbon cable problem. Glad you found it Pete.
Old Dec 16, 2006 | 03:33 PM
  #28
PETE'S_6.0PSD
i know i got my blood presure going high few times
and saying F,,, words in the front of the kid
thats never nice
but i hope it wont happen again till CPS goes bad LOL
Roger T. Pipe
Ford Truck Parts for Sale
Apr 3, 2016 07:49 PM
1966f250
Dec 27, 2014 10:31 AM
cincinnati_kid
30
Nov 4, 2009 08:22 AM
fastmover
N. California Chapter
Mar 30, 2008 12:58 AM
