C O D E S
Old Dec 14, 2006 | 08:36 PM
jeepster1272's Avatar
jeepster1272
C O D E S
Pulled theese the other day, 0470 ebp, but can theese also be caused by ebp,
0603,1105,1106? any help appreciated guru's. Thanx
Old Dec 14, 2006 | 08:39 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
P0603 is normal, for a tuned truck. I assume you have some sort of tuner on it? It is because the stock tune is removed and an aftermarket one is there now, the PCM doesn't recognize.
P1105 Dual Alternator Upper Fault (Monitor)
P1106 Dual Afternator Lower Fault (Control)
Old Dec 14, 2006 | 08:43 PM
jeepster1272
Thanks for the quick reply Strokin7.3 yiup tuner cool. The weird thing is I am not equipped with dual alternators, so I guess I won't worry about those huh? Thanx again sir.
Old Dec 14, 2006 | 08:48 PM
PowerstrokeJunkie
Try unhooking both batteries, turn your headlights on for about 20 minutes. That should reset the codes. P0603 will keep coming back most likely, but i dont know what is up with the dual alternator codes.
Old Dec 14, 2006 | 09:05 PM
Uzumati's Avatar
Uzumati
Your truck wasnt originally a dual alt setup was it?
Old Dec 14, 2006 | 10:01 PM
jeepster1272
No truck came with only one alternator. Thank you.
Old Dec 16, 2006 | 04:40 AM
AustinS's Avatar
AustinS
Reset codes then Charge your battery completely with a charger.
Turn on lights for 5-7 min to take off the surface charge and test batt voltage. Should be at least 12.5V
then test the alt the old fashioned way....
Start engine and voltage should be more than what battery tested at but not more than 14.5V.
then idle at 2000rpm and turn accessories on incl. fan blower and head lights. Shouldn't drop below what battery tested at. The stock alts are real weak anyways and the auto parts store checks are usually worthless.
They'll show alt good when its toast most of the time.
A good Voltmeter won't lie.
Austin
Old Dec 16, 2006 | 03:52 PM
jeepster1272
did what you said, replaced alternator thank all you guys, you rocK
hedhntr
Jan 31, 2011 07:01 PM
hedhntr
Jun 30, 2010 07:35 PM
ehgeeray
Mar 26, 2010 09:12 PM
jcbx
Nov 22, 2008 03:57 PM
hedhntr
Sep 10, 2007 01:31 PM
