f250 died while driving
Old Dec 2, 2006 | 05:40 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
hey guys, i have 2001 f250 , and just few minutes ago i was driving and the truck just died, so i puled over turn the key and it started right up???????
WTF?????????? can anyone tell me what might be a problem?
it kinda scared the S%$#$@% out of me,,,,,,,
i just installed 2005 f250 mirrors, heated with signal and running lights, do you think this might have somthing to do with it?
Peter
Old Dec 2, 2006 | 07:06 PM
ryaneverk2's Avatar
ryaneverk2
Have you tried replacing the CPS?
Here's a handy site from Guzzle92:
http://guzzle.rbmicro.com/cps.html
Old Dec 2, 2006 | 07:41 PM
PETE'S_6.0PSD
thanks ryaneverk2 for replaying to my post
that was on my mind, and i wanted to do it first tommorrow, its scary when 8000# truck just quits, its damn SCARY!!!!!!!!
so ill change it tommorrow
illpost back if it happens again
thanks again
Old Dec 2, 2006 | 07:44 PM
Green_Dually's Avatar
Green_Dually
I dont think your mirror have anything to do with it.
I second the cps idea.
Old Dec 2, 2006 | 08:01 PM
PETE'S_6.0PSD
thanks guys ill do it tommorrow, i have to get another one to have it on hand,just in case,,,,
Ebay again
Old Dec 3, 2006 | 01:09 AM
jtharvey's Avatar
jtharvey
Sounds dead on like a CPS beginning to fail. Hopefully replacing it will cure the problem.
Old Dec 6, 2006 | 07:24 PM
PETE'S_6.0PSD
so back to square 1, it happen 2 times today, just died, and i justput new CPS sensor
so question is, it happen after my power mirror install, i guess i have to disconect my mirrors and see if that might cause it
im just lost now, any sugestions?
it never happen before
im just mad like hell,
can my heated mirrors cause overload in the circuit?
maybe i taped in to the wrong power line?
just dont know
Peter
Old Dec 6, 2006 | 07:33 PM
clux's Avatar
clux
NO other symptoms, no sputtering, missing, it just dies, bang, like you turned it off?
Old Dec 6, 2006 | 07:37 PM
PSNut's Avatar
PSNut
Where did u get your new CPS? It could be bad too.
Old Dec 6, 2006 | 07:43 PM
PETE'S_6.0PSD
clux
no just diedn just a little puff of smoke on restart
psnut
ebay, it was new in Ford package with Ford part#
could it be a fuel problem?
Old Dec 6, 2006 | 07:48 PM
clux's Avatar
clux
I don't think it's a fuel problem with the symptoms you are describing seems wiring harness/electrical to me. Have you considered the injector harness under the valve cover? Did you disturb/unhook/splice into any ground wires when you installed your mirrors?
Old Dec 6, 2006 | 07:52 PM
PETE'S_6.0PSD
as far as the grounds, the ground screw thats under the cover by a left foot by the Hood handle, thats where i put the ground from mirror,
the only thing happen was when i took the ground off it was like i disconnected battery , everything flashed in and out, could this cause the problem?
Old Dec 6, 2006 | 07:54 PM
clux's Avatar
clux
That sounds like a very good place to start to me. Retighten that ground and make sure it has good contact, it is most like a primary ground for the PCM.
On Edit: If It was me, I would find another spot to ground your mirrors as well, just to be safe.
Old Dec 6, 2006 | 07:57 PM
PSNut's Avatar
PSNut
The problem coincided with your new mirror install....correct?
Electrical mirrors....electrical CPS...hmmmmmm.....i saw a gent
have a CPS problem when he turned on his wipers. After replacing
the CPS he said it fixed the problem. I suspect our cps's can be
a bit sensitive to greater electrical noise generated by various devices.
This was one of the benefits of the new "blue" CPS. A cleaner stronger
signal less likely to be interfered with. A theory.
Old Dec 6, 2006 | 08:17 PM
PETE'S_6.0PSD
ill do it tommorrow, ill change the grounds and change the power wire connection too,
and see if it solves my problem,
could i Fup my PCM, when i took that ground off?
