460 carb ?
Old Dec 2, 2006 | 05:00 PM
Knight70F250's Avatar
Knight70F250
460 carb ?
I would like to swap out my carb. I have a hose that comes from the intake manifold up the the choke. What is that? I know it's a dumb question, but I need help. My truck is a '69 F250 that originally came with a 390, manual choke. The engine was swapped out with a 460 (a '73 by the casting #'s) and I'm not sure if it's manual or electric choke anymore. There is a choke **** in the dash but it may be disconnected. I'm not sure, but I know it has no effect. There are no wires coming from the choke housing. The carb is a Motorcraft which means it's not as old as the engine, but I can't find a number anywhere. That's it for now. Thanks for any help.
Old Dec 2, 2006 | 09:36 PM
Mil1ion's Avatar
Mil1ion
That is for the chove stove coil for heated vacuum to run thru the choke housing to shuit off the choke after the engine heats up.
Here's a pic for your enjoyment.
https://www.ford-trucks.com/user_gal...id=134518&.jpg
Old Dec 3, 2006 | 01:53 PM
Knight70F250
Thanks Mil1ion,
That pic looks just like my set up. I bought a new Edlebrock carb that doesn't have nipples for the hoses on the choke housing. When I install it, do I cap off those nipples on the intake manifold, or should I just leave them open?
Old Dec 3, 2006 | 06:13 PM
Mil1ion's Avatar
Mil1ion
They make a smooth plate that caps that... if you can find one.
Otherwise make one out of a piece of chromed material.
or
cap the nipples
JReagan90
Sep 13, 2011 06:14 PM
jdon88
Feb 8, 2009 05:27 PM
pffan021
Oct 12, 2008 03:57 PM
towmater
Jul 27, 2007 12:08 PM
farmtwuck
Sep 16, 2005 03:32 PM
