speedo questions
Old Mar 9, 2002 | 07:48 PM
abe's Avatar
abe
Post speedo questions
The odometer on my '54 F-100 has not worked since I bought it in 1977. I took it apart to see why. The gear going from the speedo to the gear that connects to the gear that turns the odometer does not turn. I can not take it apart anymore as far as I can tell. Does it just need a lube job (and what should I use for lube). On an earlier thread or in the the good old lists there was discussion of the lube hole. I found it but it was full of crud. What kind of lube do you use and how do you get it in the hole? I have another speedo that the odometer works but the speedo doesn't! Any solutions. One can not find a speedo shop anymore nowdays.
Thanks, Abe
Old Mar 9, 2002 | 08:26 PM
46fordtruck's Avatar
46fordtruck
speedo questions
If your speedometer needs to be fixed or recalibrated check out United Speedometer Service in Riverside, CA. They have a website, www.speedometershop.com. They have been around since the '50's and do very good work. And for the lube, I think watch oil will work for it. You don't want to use anything too heavy.
Gary
46 truck-6cyl now, 302/C4 soon
46 truck-flathead 8, 4spd
47 truck-getting a 429/C6
57 Ford FL 500-4 dr-312/AT
70 Mustang fastback-351W/FMX
72 Olds Vista Cruiser-350/AT
88 Bronco II, 500,000+ mi.
Old Mar 10, 2002 | 04:31 AM
cabby daddy's Avatar
cabby daddy
speedo questions
ABE,
I don't know where you are located, but I use speedometer service and instrument , located in portland, 1-800-634-2145 . They have always done me right...
I go there cuz my daddy goes there.... and he goes there cuz his daddy went there....
Robert
Old Mar 10, 2002 | 10:52 AM
jaye's Avatar
jaye
speedo questions
Jeramyb
Dec 14, 2014 08:58 PM
Bob_Smith
Aug 21, 2012 06:23 PM
thordehr
19
Nov 22, 2010 11:09 PM
dennisb56
Aug 18, 2007 08:22 PM
