Can someone tell me how you go about setting an odometer to all zero's. I had to replace the speedo as the old one did not work. The cable from the transmission does turn, so I got another speedo on ebay. It works. I figure I might as well set the mileage to zero as a starting point. I figure I take the old one apart to try to reset it before I break the new one. Any ideas will be appreciated.
Take the speedo apart and turn the numbers...I would turn them from the back with a blunt object apply pressure and turn make sure you don't press to hard and scratch the numbers off, you will also have to go forward to get each number to zero. My 2 cents
