low oil pressure????
Old Dec 3, 2006 | 05:13 PM
  #31
gofast66's Avatar
gofast66
on the injector. am I looking where it goes into the head or where the log connect's to it or both?
Old Dec 3, 2006 | 05:26 PM
  #32
BowTieHatr's Avatar
BowTieHatr
look where each injector connects to the log, the quick connect fitting into the log rail, and the quick connect fitting to the standpipe.
Old Dec 3, 2006 | 05:37 PM
  #33
gofast66's Avatar
gofast66
GREAT... I'll keep you informed
Old Dec 3, 2006 | 08:06 PM
  #34
gofast66's Avatar
gofast66
OK here we go... pulled right valve cover and started engine... could see oil being sprayed around number 3 injector,a little less around number 5. turned on the high idle and low and behold, alot more oil...I guess that new o-ring's are in order...I'm just gonna replace all of them..these oil log's or rail's (what ever they are called) do not have a high pressure hose on them, there is a removable tube that comes from the lifter valley and goes into the log with an o-ring to seal it... that little tube that comes out of the log that goes into the injector,is there any way that that can leak? is ther an 0-ring inside that? as it is really hard to see exactley where the oil is coming from,either from the injector or that tube?
Old Dec 3, 2006 | 08:26 PM
  #35
BowTieHatr's Avatar
BowTieHatr
ok you have the wave rail. you are going to have to replace the injector(s). also that tube oyu removed is part of the standpipe. there are 3 orings if i am not mistaken which you need to replace but you will probably have to order them.
Old Dec 3, 2006 | 08:57 PM
  #36
gofast66's Avatar
gofast66
I'm confused (again) stand pipe o-ring=one on each end? can't buy o-ring for inside injector? have to buy new injector just for o-ring? that little metal tube that sticks out of the wave rail, that goes into the injector(ha ha) know what I mean? my question is, is there an 0-ring or anything ther that goes bad?
Old Dec 3, 2006 | 09:30 PM
  #37
BowTieHatr's Avatar
BowTieHatr
the tube was i believe was a 1/2 drive tube correct?
Old Dec 3, 2006 | 09:32 PM
  #38
gofast66's Avatar
gofast66
not sure if i understand? but i think so?
Old Dec 3, 2006 | 09:33 PM
  #39
BowTieHatr's Avatar
BowTieHatr
i mean that you used a half inch ratchet to remove it right?
Old Dec 3, 2006 | 09:39 PM
  #40
gofast66's Avatar
gofast66
no the tube that goes down to the lifter valley has an o-ring on the end and slipps into the wave rail..
Old Dec 3, 2006 | 09:41 PM
  #41
BowTieHatr's Avatar
BowTieHatr
ok i mean like it was kinda like a pipe plug with a 1/2 drive head about 3 or 4 inches long right?
Old Dec 3, 2006 | 09:43 PM
  #42
gofast66's Avatar
gofast66
no there were plugs on the wave rail like thet but nothing that i had to take apart.
Old Dec 3, 2006 | 09:46 PM
  #43
BowTieHatr's Avatar
BowTieHatr
ok so all you did was take the 8 torx bolts out then right? i am trying to picture what you have done so far so i can tell you where to go. in the wave rail, there are 2 1/2 drive pipe plugs. the one close to the front and one at the rear that is probably sticking out correct?
Old Dec 3, 2006 | 09:49 PM
  #44
gofast66's Avatar
gofast66
do not remove them, just removed the torx and lifted it off of the injector's ond of the engine.
Old Dec 3, 2006 | 09:53 PM
  #45
BowTieHatr's Avatar
BowTieHatr
ok i got you. that pipe that is still in the head is part of the standpipe. remove it from the head and you will see two D-rings. look in the head where that tube went and you will a hollow shaft. grab it very carefully on the OUTSIDE so you wont damage it, and pull it out as well and you will see a D-ring on the end as well. you will want to replace these as well as the injectors.
