Sponsored by: Auxito
Changing the differential fluid
Old May 20, 2016 | 11:41 PM
  #31
GadgetGuy22's Avatar
GadgetGuy22
I wonder if it would drain more thoroughly if the front wheels were on ramps.
Old May 21, 2016 | 03:32 AM
  #32
blupupher's Avatar
blupupher
Not really, unless the front end was at a 70° angle or something. The area where the extra fluid is pooled is deep, and a rag and your hand can clean it out easily.
Old May 23, 2016 | 01:06 AM
  #33
GadgetGuy22
Later on today I'll be finishing changing the fluid.
Would it be ok to put anti-seize lube on the cover bolts & fill plug?
Damn...just noticed my signature is gone!?! WTH!
Old May 23, 2016 | 12:52 PM
  #34
steve(ill)'s Avatar
steve(ill)
you don't need anti seize on the bolts ....... and the plug should be fine without.. if anything, maybe a drop of pipe dope for sealer.
Old May 25, 2016 | 02:22 AM
  #35
GadgetGuy22
Thanks Steve & everyone. You are always very helpful people!
I successfully finished it yesterday. But WHAT A PITA REFILLING IT WAS!! I used the attaching a hose to the bottle method & made quite a mess with spilled oil down my arms & on the driveway cause the hose wouldn't stay on the bottle. Someone had mentioned removing the ABS sensor on top of the diff & putting the oil in there which would probably be much easier but I was concerned about dirt or rust falling in.
I only had Teflon tape to put on the plug. I hope that was ok.
Old May 27, 2016 | 11:43 PM
  #36
GadgetGuy22
Anyone know if filling the frt diff is any easier?
Old Feb 26, 2017 | 01:23 AM
  #37
Audi Junkie's Avatar
Audi Junkie
Skip anything Lucas
Old Feb 26, 2017 | 09:13 AM
  #38
BlueOvalFitter's Avatar
BlueOvalFitter
My go to differential fluid used to be RED LINE. Since I have retired, my go to fluid is M1, Valvoline, or Super Tech.
Also, I have ALWAYS used a gasket with an ultra thin bit of RTV smeared onto both sides of the gasket. I have been known to use 3M yellow sealer in the past as well.
A couple of tips here;
1) If your differential calls for friction modifier, don't rely on a fluid that states the modifier is already in the fluid. Buy the required amount of modifier as well.
2) After doing the fluid and modifier install, go find an empty store parking lot. Do a series of figure 8's (about 8-10) to evenly disperse and mix the modifier with the fluid.
MikeDVB
2015 - 2020 F150
Feb 6, 2018 05:30 PM
F250_
28
Jun 26, 2017 08:09 AM
steeleygreg
Mar 12, 2017 10:42 PM
CapeMay609
2004 - 2008 F150
Sep 17, 2016 02:06 PM
c96drumm
Aug 13, 2016 08:21 AM
