92 F-150 Question
Old Dec 2, 2006 | 01:44 AM
Jrock909's Avatar
Jrock909
92 F-150 Question
My dome light works, but both of my courtesy lights don't work? Can you guys please tell me what the bulb number is for those lights? It's the lights that are in the interior dome light.
Thanks
Old Dec 2, 2006 | 07:13 AM
HomerWinzlow's Avatar
HomerWinzlow
If you remove the bulbs and take them to any parts store they should be able to match them up. There are many different types used.
Old Dec 2, 2006 | 09:08 PM
Franklin2's Avatar
Franklin2
I am assuming you mean the map lights? If new bulbs don't fix it, check the wiring down near the floor on the driver's side behind the seat, and also where it goes under the door sill plate. It leads a rough life there and the wires can corrode. These are what feed all the lights in the top rear of the cab.
Old Dec 2, 2006 | 10:40 PM
Jrock909's Avatar
Jrock909
Thanks Franklin, do you know the wiring colors that run power to those map lights?
Old Dec 3, 2006 | 02:05 PM
Franklin2's Avatar
Franklin2
The maplights are powered by a lightgreen/yellow wire. It's hot all the time and comes from the fuse box.
Along with it will be a black/lightblue wire. That is the domelight wire.
There may also be a black/pink in the harness. This is for the cargo lamp on the outside back of the cab.
Old Dec 3, 2006 | 09:10 PM
Jrock909's Avatar
Jrock909
Franklin is there a fuse just for the maplights, for some reason there isn't any power to those map lights? I had a car alarm put in about a year ago and I am wondering for some dumb reason they disconnected them....
Old Dec 5, 2006 | 09:11 PM
Franklin2's Avatar
Franklin2
That fused lightgreen/yellow wire is power for the domelights and the map lights.
Old Dec 5, 2006 | 09:32 PM
Jrock909's Avatar
Jrock909
So the it has something to do with the domelight housing itself then, if the map lights don't work, because my dome lights work just fine then....? What you think? Have you ever seen that, where the map lights won't work anymore, but the domelight is fine?
Thanks Franklin
Old Dec 7, 2006 | 12:18 AM
Franklin2's Avatar
Franklin2
If you take the dome light apart, and have power on the lightgreen/yellow wire in the housing, then yes I would suspect a problem possibly with the switches in the housing.
ctboyle03
1983 - 2012 Ranger & B-Series
May 31, 2019 05:31 PM
Doubleubar
Feb 24, 2016 06:33 AM
z31freakify
Nov 29, 2015 09:19 AM
84StraightSix
Aug 31, 2014 12:35 PM
rpstrong
Dec 13, 2013 06:47 PM
