Fuel filters?
Old Dec 1, 2006 | 05:02 PM
99F350PS's Avatar
99F350PS
Fuel filters?
Is there 2 or 1 fuel filter on the 6.0L Power Stroke. The manual says to replace the filter on the engine and the one on the frame rail. To my knowledge there is only one filter. Am I right.
Thanks
Old Dec 1, 2006 | 05:09 PM
blackhat620's Avatar
blackhat620
Thanks
Nope the Manual is correct. There are two. Look in the tech folder for more info and also down a few posts and Jeff (Beachbumcook) has posted pictures
http://www.ford-trucks.com/forums/30...ch-folder.html
http://www.ford-trucks.com/forums/54...-look-for.html
Hope this helps
Old Dec 1, 2006 | 06:23 PM
barrelhorses's Avatar
barrelhorses
There are definitely two. The one on the frame rail (HFCM) is sort of a PITA to change unless you have the right tools on hand. You'll need a 36mm socket and a 6mm allen wrench to drain the HFCM before you take the cap off.
You can get the filters (they come in one box together) at a local International dealer for much less money than at a Ford dealer. The Part # is 1847170C92. I think my last set was about $32.
Old Dec 1, 2006 | 06:29 PM
Minnesota Sun Bird's Avatar
Minnesota Sun Bird
on fuel filters
To all you knowledgable folks out there. My manuel instructs me to change the filter when you get the water warning light on the dash as well as specific intervals.. I must confess that i have 40,00 miles on my 2004 and have yet to see a water warning light, nor have found any water in the filter under neath the truck, when I've checked. And I have not changed the filters. Am I playing with fire?
Last edited by Minnesota Sun Bird; Dec 1, 2006 at 06:32 PM. Reason: Truck is 2004 SD
Old Dec 1, 2006 | 06:38 PM
WishIhada7.3's Avatar
WishIhada7.3
its prob just safe to do it every/every other oil change.
Old Dec 1, 2006 | 06:42 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I change mine every 10-15K and the one on the frame really catches a lot of stuff. When you take it off cut it open and look between the pleets.
Old Dec 1, 2006 | 06:46 PM
blackhat620
Well if you look at the manual a little closer it will tell you to drain the HFCM at every oil change and anytime that the WIF light comes on. You are supposed to replace the fuel filters every 15K miles minimum and at 10K miles for severe service use.
The fuel filters do not only stop water but other contaminents as well. And yes in my opinion you are playing with fire by not changing the fuel filters at least every 15K miles. If the injectors get starved for fuel do to restricted filters or contaminents get passed a bad filter, it can cause injector damage and premature wear.
Hope this helps
Old Dec 1, 2006 | 08:06 PM
Bevis3's Avatar
Bevis3
I know someone that the above statement has happened to them...I asked when the last fuel filter change was...he shrugged his shoulders and said I dunno, who cares.
Old Dec 1, 2006 | 08:24 PM
bigredtruckmi
Veteran: Navy
This is why I keep my maint. records on the fordvehicle web site. This shows when it was last serviced what was done and costs, this is from a ford dealership entering in the info. I even keep my records for the vehicle on there for future reference if there is any question on when a service was done
2006FordF250
Aug 22, 2014 05:16 PM
Fabbed5.0
Oct 4, 2013 12:11 PM
99F350PS
Oct 23, 2006 09:54 PM
What Man
Jan 29, 2006 04:02 PM
FordTruckMan7900
Aug 16, 2003 04:30 AM
