Sponsored by: Real Truck
Extra fuel Tank
Old Dec 1, 2006 | 07:13 AM
mhs53's Avatar
mhs53
Extra fuel Tank
I'm looking at a tool box combo 60 gal fuel tank unit from Northern Hydraulic Co. Has anyone ever bought one of these and if so is it ok?
Old Dec 1, 2006 | 07:30 AM
Stevie Ray's Avatar
Stevie Ray
Funny the extra fuel tank question came up. Just yesterday I was talking with one of our customers who has been having some weird 'check engine' and so forth lights on his '03 or '04 F250 (gas) truck who also runs an extra fuel tank. Evidently his dealer tried to get out of the warranty work because they said by tapping into the fuel system with the extra tank was causing all of his problems ... said that was strange because the same tank has been on all three of his previous Ford trucks and couldn't begin to tell me how many hundred of thousand miles between the three without nary the first issue. Sounds like a crock to me.
As to your question, I don't know, sorry.
Old Dec 1, 2006 | 12:54 PM
rwilimo's Avatar
rwilimo
Depending on the install and how the tank is connected I could see this causing evap type codes and a service light. Every few years the spec's are tightened on Evap leaks. I am not saying that it is definitely bad, I just think it is possible.
Old Dec 1, 2006 | 02:01 PM
mhs53's Avatar
mhs53
The connection is made in the fill neck hose. A tee is inserted and you have a 3/8 hose with a manual shut off valve. You run your factory tank down then fill back up and shut the valve. It doesn't actually tie into the factory fuel lines to the motor or any guage wiring. I pull a fifth wheel camper and wanting to limit my stops at truck stops. Seems like some truckers and truck stops don't like use because we or on vacation while they are working and the station wants more than a 30 gal sale.
Old Dec 1, 2006 | 03:52 PM
rwilimo's Avatar
rwilimo
Well then as long as that connection/tee/valve is absolutely leak free then it should not effect the service engine light. Just remember that even the slightest fuel vapor leak will be noticed by the PCM
Old Dec 1, 2006 | 07:00 PM
Don Tim's Avatar
Don Tim
I run the transflow 50 aux tank and have never had a problem one. it is great to have 80 gallons on tap. It also has a pump and comp control to balance the transfer so both tanks go down at the same time. I most certantily cant complain with approx 1000 mile range before fillups.
Old Jan 5, 2007 | 05:32 PM
garycraze's Avatar
garycraze
Anyone done the fuel tank replacement / upgrade?
Anyone done the swapout to the larger aftermarket fuel tanks, such as the ones from Tranfer Flow?
I'm looking at the 46 gallon midship replacement tank for my '03 F250 crew short bed. That's about 20 gallons more than the stock tank, or roughly slightly under double the driving distance.
Thanks in advance!
timpage
27
Aug 10, 2016 10:53 PM
creedua
Nov 22, 2014 02:53 PM
swampthang
Mar 3, 2014 12:49 PM
Jon774
6.7L Power Stroke Diesel
Dec 23, 2013 04:25 PM
60RatRod
Oct 12, 2010 08:08 AM
