55 IFS
Old Jul 4, 2001 | 10:38 AM
garylm's Avatar
garylm
55 IFS
I'm looking for a bolt on IFS for my 55 f100. I really don't want to cut my truck up. I thought I read of a company that had a bolt on IFS kit. Anybody have any suggestions.
Old Jul 4, 2001 | 10:46 AM
jaye's Avatar
jaye
55 IFS
I don't think you are going to find a truly bolt in IFS, if you buy the cross member you still need to weld it in place. You can get a sub frame and bolt it in but you still need to weld it for stability and strength. If you find one let me know
Old Jul 5, 2001 | 10:12 AM
bobs53's Avatar
bobs53
55 IFS
There is a place called Chassis Tech which makes a easy install clip. It uses the front bolts of your front cab mounts, you do have to cut your frame but you run a bead of weld around where you cut it for strength. It gives you all of your stock location for bumper, and radiator. You use GM components for your suspension. It will also give you about a 5 inch drop. This is what I will use for my 53'.
Old Jul 6, 2001 | 12:58 AM
garylm's Avatar
garylm
55 IFS
Thanks, do you know where they are located???
Old Jul 6, 2001 | 09:24 AM
tkbowman's Avatar
tkbowman
55 IFS
[font size="1" color="#FF0000"]LAST EDITED ON 06-Jul-01 AT 10:27 AM (EST)[/font][p]There's no bolt in IFS kit that I'm aware of. Gibbons comes the closest and they use a set of Volare type components. I probably have one of their brochures if you'd like me to scan it. Or do an internet search on Gibbons Fibreglass or Engineering out of Iowa.
I'm coming down close to the end on the installation of a TCI Mustang II front crossmember. It does not require cutting any of the frame. I've found it to not be a hard job, just a little time consuming.
The steps I've followed so far are:
Using a torch (Henrob), I cut the ends of the rivets holding the front suspension brackets to the frame.
Removed the front suspension.
Welded up the unneeded holes and ground the welds.
Next Steps:
I'm now getting ready to weld the boxing plates to the inside of the frame and then I'll weld the crossmember to the boxing plates. Note that I'm moving the front wheel centerline 1 1/4" forward to properly space it in the wheel opening.
The next step is to weld the spring towers in place.
Install the tubular A-Arms (one could use stock if desired).
Pictures of my progress are found on my website. I also know of a link to a set of sequential pictures where a fellow installed a crossmember kit in one weekend. They're pretty informative. Write me if you want the link.
Tim in Burien
website: www.users.qwest.net/~tkbowman
(Pacific NW Carshow Information & More)
tkbowman@qwest.net
Old Jul 7, 2001 | 02:10 AM
bobs53's Avatar
bobs53
55 IFS
Chassis Tech is located in Redding CA. E-mail me at Leifermanb(No Email Addresses In Posts!) and i can give you more info.
Old Jul 25, 2001 | 02:40 PM
alexdixie's Avatar
alexdixie
55 IFS
I have installed a 1986 Jaguar XJ6 front member in my 1950 F1, was a very easy swap and I did not need to cut the frame at all. Took 1/2 day to install. Very easy. Can email you an article that appeared in Custom Car here in the U.K.
Regards
Alex
Old Jul 25, 2001 | 05:50 PM
mike55's Avatar
mike55
55 IFS
I would like a copy of the jag front end swap at mlobner@home.com
Old Jul 26, 2001 | 07:12 AM
tlak's Avatar
tlak
55 IFS
I would like a copy of the jag front end swap at tlak@scrtc.com
Old Jul 26, 2001 | 10:23 PM
truckfarmer's Avatar
truckfarmer
55 IFS
I would like a copy also at trukfarm@frontiernet.net Thanks
Old Jul 27, 2001 | 01:30 AM
garylm's Avatar
garylm
55 IFS
Thats sounds good. Mail me a copy at garylm@qwest.net
Old Aug 1, 2001 | 11:12 PM
fatherford's Avatar
fatherford
55 IFS
hey could you email me a copy too.. FATHERFORD(No Email Addresses In Posts!)
78 F150 400m, c6, holley carb and intake, cam, and some other goodies
87 F150 460, c6, 2800 stall converter, eagle hbeam's, eldelbrock intake carb, crane cam sat spec., balanced and blue printed, 10.5-1 compression, heads ported and polished, full msd setup, everything but roller, aluminum heads, and laughing gas(as for now).
55 F100 stock 292 3 speed (as of right now..heh)
97 Exped stock
Old Aug 2, 2001 | 08:41 AM
denisontexas's Avatar
denisontexas
55 IFS
Hi,
I would like a copy of that information as well.
To make it easier on everyone (including yourself), I can post it on the web for everyone to view. (If you don't mind)
Thanks
Mike
Old Aug 4, 2001 | 07:08 PM
286merc's Avatar
286merc
55 IFS
Add me to the Jag list and tnx to the guy who just offered to post it...let us know when its up.
Complete running but unibody rotted Jags are $100-300 around here!
Old Aug 14, 2001 | 08:36 PM
effie55's Avatar
effie55
55 IFS
I am also interested in the Jag swap. Please post the article, thanks
