55 IFS
Old Aug 15, 2001 | 12:21 AM
bjorny_17's Avatar
bjorny_17
55 IFS
hey, could I also get that artical... bjorny_17(No Email Addresses In Posts!)
Old Sep 4, 2001 | 04:51 PM
effie55's Avatar
effie55
55 IFS
Hi Alex, I have a 55 F100 in need of a good clip. I am very interested in the Jag swap. Please post it to my FTE mailbox, or my email. Thanks, John
The address is: jcdawson_us(No Email Addresses In Posts!)
p.s., I'm also interested in a rear swap. Do you have the info for a Jag rear as well? Thanks again
Old Sep 5, 2001 | 04:03 PM
effie55's Avatar
effie55
55 IFS
Where's "around here" ? I'd like to find a "rotted body" Jag for the front as well as the rear end. Thanks
Old Sep 5, 2001 | 06:47 PM
truckzilla's Avatar
truckzilla
55 IFS
Add me to the list to sent the article to
truckzilla@quiknet.com
Old Sep 25, 2001 | 05:37 PM
jaye's Avatar
jaye
55 IFS
RB'S has a bolt in IFS for a 47-55 chevy, they may carry one for the ford.
1-887-894-0570
Old Oct 24, 2001 | 02:25 AM
460pu's Avatar
460pu
55 IFS
I'm building a '56 and used a Gibbons kit. True bolt in. Uses
mid '70 Mopar front suspension parts. No welding, bolts into existing holes in the frame. Gibbons Fiberglass Reproductions
843-395-6200. Good luck.
Old Oct 24, 2001 | 09:27 AM
55FordLover's Avatar
55FordLover
55 IFS
how hard is it to find those parts for the IFS of the MOPAR...have a 55 F100 too and thinking of doing the same exact thing....
55 Ford F100
302 w/AOD
still in the works...
running 223/3spd :-)
Old Oct 25, 2001 | 12:56 AM
460pu's Avatar
460pu
55 IFS
I live in south central PA and had no trouble locating a donor car. Even found a local small town Mopar dealer that had or would order parts to rebuild the front end. Gibbons was also helpful in locating parts. Very easy install less than 4 hrs.
No welding. crossmember lines up to existing holes in the frame. Just bolt it in and add the Mopar parts. If you live near a car/truck show that Gibbons attends talk to them about bringing your parts to the show and save the freight. The guy I dealt with is Kyle Bond at the SC shop. 843-395-6200 GOOD LUCK
Old Oct 26, 2001 | 07:13 AM
51f1's Avatar
51f1
55 IFS
Looks like you've opened a can of worms! Would you send it to me, too? christian1025@prodigy.net
Thanks!
Erik Christian
'51 F-1 daily driver
Old Nov 1, 2001 | 12:12 PM
jprippin's Avatar
jprippin
55 IFS
well im a brand new member and i cant find where anyone posted where to get the jag info so if someone would put that in this thread that would be cool for many,..or add me to the list of me toos
thanks jp/55f00
Old Nov 2, 2001 | 06:25 PM
ghaener's Avatar
ghaener
55 IFS
Please add my name to the list of truckers you are sending the Jaguar front suspension article to. ghaener@voyager.net
Old Nov 2, 2001 | 06:29 PM
ghaener's Avatar
ghaener
55 IFS
Exactly which mid seventies mopar front suspension is used or will fit
Old Nov 2, 2001 | 06:36 PM
  #28
ghaener's Avatar
ghaener
55 IFS
Is this the front frame clip that is sold by RB's? The one that uses 78 to 88 GM "A" or "G" body front suspension.
Old Nov 4, 2001 | 11:09 PM
  #29
460pu's Avatar
460pu
55 IFS
Use front end parts from 75 - 78 Chrysler cordoba. There are other donor cars. Contact Gibbons at 843-295-6200 or check out their website www.gibbonfiberglass.com
Old Nov 5, 2001 | 10:53 PM
  #30
tkbowman's Avatar
tkbowman
55 IFS
FYI, the December issue of Custom Classic Trucks (Yellow '56 F100 on the Cover) has a long article on front suspension options.
Tim in Burien
'56 F100 in Progress
