tranny belching fluid
Old Nov 30, 2006 | 08:50 PM
sporteeone's Avatar
sporteeone
I have a 2000 F250 7.3 w/4R100 that I tow a 5th wheel trailer with. I have 85,000 mi. on the clock, with about 30,000 mi. hitched to the trailer. Tranny operates normal 99% of the time. The other 1% it will belch 1 to 2 quarts of fluid out of the front seal. This occurs after reaching normal operating temps 165 degrees, followed by hard pulling raising the temps to 200 degrees, followed by parking the rig at the elevated temp which results in the fluid drain. It makes no difference if I idle in place or shutdown, both procedures dump fluid. My tranny guy says the front seal is the culprit and seal replacement is fruitless as he has had no success with it. Tranny has a MagTech pan and fluid is cherry red and odorless. I know with the heavy duty the tranny will fail someday, just thought this problem would be preventable. Any ideas?
Jon
Old Nov 30, 2006 | 09:11 PM
Fat Diesel's Avatar
Fat Diesel
Were you backing up when it happens? That is pretty much normal for a stock trans to blurp some fluid when warm/hot and backing slowly. I've been watching the forums for years and that seems to be the consensus. There are options for putting better trans coolers on that should solve your problem. Someone with a 6.0 or TrueCool will no doubt chime in.
Welcome to the forum. You'll learn a ton on this site.
Old Nov 30, 2006 | 09:19 PM
sporteeone's Avatar
sporteeone
Thanks for your reply. No I wasn't backing up, however the last 1 mile to my destination has uphill grades which require 1st. and 2nd. gear for prolonged periods.
I've been lurking and soaking up info for years on this site and found it helpful. Plan to add a V10 or 6.0 OEM cooler swap if my temp is the problem. Temp sensor is tapped into the tranny pan.
Old Dec 1, 2006 | 06:06 AM
Poohbear's Avatar
Poohbear
Sporteeone, Just thought I would chime in. Ive got a 02 F550 with same tranny that I pull a #15000 5th wheel and I was also pulling a steep grade when I noticed smoke from under truck I looked at stock gauge and it was peged and suddenly it quit pulling. It had blown a lot of fluid out and it was coming off of bell housing area. I first thought it was a seal. I had it towed and was thinking of a new tranny. but a few days later I filled it back up with 14 quarts of fluid and it works fine. Ive pulled my trailer with no problems. The only thing I can figure is I dont have yet, a add on cooler and it run hot and burped fluid out the vent on top of tranny above the bellhousing area. Goodluck hope this helps.
Old Dec 1, 2006 | 06:46 AM
Orezona's Avatar
Orezona
I've had mine to 198 from hard uphill pulls and it never belched fluid. Somebody on here will have some good suggestions.
Old Dec 1, 2006 | 07:17 AM
Casey's Avatar
Casey
Does your truck have a trans cooler in the radiator? Ford added that mid year in 2000. Without the radiator cooler the front seal would overheat backing up or in low speed, high load conditions. When the seal overheats it relaxes and loses it's sealing capability.
If you don't have a radiator cooler, change the radiator for one that does. That is the best way to keep it cool. A better air to oil will help, but only with a big electric fan blowing on it. The stock fan doesn't draw enough through the trans cooler to help a whole lot.
Old Dec 1, 2006 | 07:20 AM
white Buffalo's Avatar
white Buffalo
Sporteeone,
If you decide to add a bigger cooler I would suggest also adding an inline filter. If something does blow in your tranny the filter will at least save your cooler. Were do you live? Faubion Motorsports rebuilt my tranny and many other 4R100's that blast up & down the track in Noble, OK. He's a great tranny guru outside Oklahoma City. Send me a PM and I can zap you his contact info if you like.
Old Dec 1, 2006 | 10:31 AM
Highmark18's Avatar
Highmark18
I had a similar experience on my 01. Mine actually started belching fluid out the front seal when it was -15 below outside, tranny temp about 145 degrees. I lost 1, maybe 2 quarts. I was going to take it out west on a trip, but decided I better not, and thought I would get it fixed when I got home. Anyway, the next week when I got home, I drove it 140 miles back to my house, didn't leak a drop. Could not get it to leak again. Took it in to my tranny guy, he said it wasn't leaking now, but I told him to replace the front seal anyway. He did some research and told me there was actually an updated "blue" seal for that tranny. Anyway, I had him replace the front seal, and it hasn't leaked since, and I have worked it pretty hard.
96f150
May 25, 2010 10:22 PM
joeyoung2008
Jun 2, 2009 06:43 PM
inline 6
Escape & Escape Hybrid
Mar 16, 2006 10:35 AM
Bluesbandit
Sep 18, 2004 10:58 PM
Schmavic
Offroad & 4x4
22
Jun 5, 2004 11:52 PM
