Tech Help On Motor Sound
Old Nov 30, 2006 | 01:51 PM
JRM6868's Avatar
JRM6868
I have an 06 f350 6.0 cc 4x4 when my truck sits for two or three days the truck will start and the oil pressure goes up there is a urrrrrup sound that happens.It seems to be in the lower passenger side of the motor.I repeated the sound with the heater on and off.Any ideas? It almost sounds as if something sags down when the trucks not running for two days and after its started its winding back up and setting itself back in place.
Old Nov 30, 2006 | 05:13 PM
BowTieHatr's Avatar
BowTieHatr
you sure its not the vacuum pump? maybe its growling at you for not driving it enough!!lol
Old Dec 1, 2006 | 09:12 AM
JRM6868's Avatar
JRM6868
Where would the vacuum pump be located? It just started doing this about a month ago. Part of the problem is I drive this thing almost every day and it just doesn't sit that much for me to check it all the time.Would the vacuum pump make the sound from the passenger side low in the engine? And to answer the last statement, I hope it's not mad at me because the truck knows I love it I tell it so every time I get in it!
Old Dec 1, 2006 | 09:18 AM
vloney's Avatar
vloney
possible ac compressor cycling? They make a grunting sound, almost like a thump at first start. Try with defrost on and off.
Old Dec 1, 2006 | 09:46 AM
Enomra's Avatar
Enomra
It sounds like the vacuum pump to me. my 03 and 06 made the same sound. It does seem to be more noticable when they sit for a while. And yes they are mad at you for not driving them every day (in thier view it is like you are cheating on them) So quit your cheating and
Drive them!!!!!!!!!!!!!!!!!!
Armone
Old Dec 1, 2006 | 10:04 AM
JRM6868's Avatar
JRM6868
Armone
I guess I offended it by thinking it needed a breather, it's ten months old with 34,000 miles on it.I think after reading your guys posts that it is the vacuum pump.It's not the heater shutting because it's not thumping,so what you guys are saying it's nothing to worry about?
Old Dec 1, 2006 | 10:29 AM
BowTieHatr's Avatar
BowTieHatr
ya it normal. just worry when you dont hear the noise!! just pop the hood and get someone to crank it. the vacuum pump is bolted to the right side fender apron.
Old Dec 1, 2006 | 10:34 AM
Enomra's Avatar
Enomra
I might be wrong but the vacuum pump should activate with the key on not just whith the engine running!!!!!!!! So pop your hood and turn the key on and I think she will purrr right along. A tech will hopefully correct me if I'm wrong on this but I believe I have heard mine with the key on......
Old Dec 1, 2006 | 10:37 AM
BowTieHatr's Avatar
BowTieHatr
yeah it will run keyed on.
Old Dec 1, 2006 | 10:59 AM
Enomra's Avatar
Enomra
THX for confirmation BTH
Old Dec 1, 2006 | 11:16 AM
JRM6868's Avatar
JRM6868
Thanks next time it sits for a couple of days I'll try to just turn on the key and see if it does it without starting the engine.
fordman19762003
2004 - 2008 F150
Mar 13, 2012 10:38 PM
zaven
Modular V8 (4.6L, 5.4L)
Dec 8, 2010 04:53 PM
wcmtlmaz
2004 - 2008 F150
Jun 9, 2008 06:28 AM
wcmtlmaz
Jun 4, 2008 12:06 PM
katbird704
22
Apr 11, 2007 06:28 PM
