Sponsored by: Real Truck
2001 F250 O2 sensor install
Old Nov 30, 2006 | 11:38 AM
ArtieSharp's Avatar
ArtieSharp
2001 F250 O2 sensor install help?
I have decided to start trying to do work on my truck myself and my first problem I have to fix is the O2 sensor. I was hoping someone could give me some guidance on installing the O@ sensors on my 2001 F250, Super Duty, V8 5.4 liter 4wd. I hear its not that difficult so I thought it would be a great place to start. I appreciate any help you can give. Thanks.
Old Nov 30, 2006 | 03:16 PM
jim henderson's Avatar
jim henderson
I do not have specific knowledge about your model so my advice is general.
The O2 Sensor/Sensors is/are mounted on the exhaust pipe. If you have a dual pipe you may have as many as 4 sensors.
Usually the sensors are mounted after the cat, and often there is a second set before. Usually the ones after the cat are the ones going bad if I recall. Don't quote me on this.
The sensors are sometimes difficult to break loose. You can usually use an open end wrench or a big socket. There are also special sockets for O2 sensors if yours is a real pain. I like to spray a sensors threads with some penetrant like liquid wrench to help loosen it up. I usually work on them cold, don't want to get burned and also I think when cold they come out easier. Worst case you might need to heat the pipe around the threads with a torch to loosen it.
When you get the new sensor check to see if there is already antisieze compound on the threads. It is kind of a silvery paste. If there isn't any, go buy a tube, it may last you a lifetime. You only need a dab on the threads. DO NOT get any on the sensor head itself. Anti sieze is also good on spark plugs, lug nuts and other fasteners that are prone to rusting stuck. Just a dab.
If you have a shop manual snug them to spec. Or snug to a good solid hand tight. Be careful not to stress the wires or any flimsy parts. Some sensors have like a sheet metal collar that doesn't take much stress. I even think some of them have plastic parts where the wire comes out.
Good Luck, this is usually an easy repair,
Jim Henderson
Old Nov 30, 2006 | 06:30 PM
ReAX's Avatar
ReAX
First to do the o2's buy the proper wrench. Lisle makes a nice socket for about $15, it fits the o2 sensor, but is slotted for the harness.
My next trick is to spray the old o2 with penatrating oil, let it sit for about 30 minutes to soak in. Run the motor for about 5 minutes. The pipe will be hot, so be careful, but it will be as lose as it will be. If it's still tight, tap the end of the wrench with a rubber mallet.
For install, be careful, the new sensor has nevr seaze on it. Don't get it in the sensor or all over you. With the pipe still warm, install the sensor and snug it up.
svtcobra041
1997 - 2003 F150
Jul 15, 2010 09:19 AM
bhmudder11
Exhaust Systems
Apr 12, 2009 11:48 PM
Gmeanie
Dec 3, 2008 01:39 PM
fordbuilder
1997 - 2003 F150
Jun 28, 2005 10:40 AM
