I had the O2 sensor on the drivers side front replaced and it fixed the engine light ON problem.
Now thou every once in awhile I hear a click or two from the engine on my driver side electronic related and then the engine starts idling real rough. I then turn the truck off and back on and the truck runs normal. No engine light comes ON when it is running rough?
I rather not go back there because they will give me the usual BS and say it isn't doing it.
Any idea's?
2001 F250 5.4 78K miles
since you just had the O2 sensor done I would start there. Get under the truck and check it to make sure it was installed properly and that the wiring is ok.
You can go to autozone if there is one close by and have them check for codes, there may be one in there.
