4x4 issues...
Old Mar 6, 2008 | 01:48 PM
  #31
bryonwleeper22's Avatar
bryonwleeper22
I have a 78 F250 400ci, Np435, NP205, 60Rear, 44 Front. To add to that I have never ever stopped shifting from 4Lo - 2Hi Or 4Hi - 2hi (unless I was stopped already). I keep moving slow and gently pull on the T-case shifter it will slide into neutral. If it's a stick I have never had a problem shifting trans to N, and let out the clutch real quick and push it back in (don't know if this helps or doesn't I just do it). The she slides right into Hi if you give it a smooth tug (You can feel it engaging) without any noise. Once in 2Hi just drop into gear and go. My truck is a beast to shift Out of 4Lo when stopped and have busted linkage before. In fact since then 8 years ago I have done it this way. After playing in the mud with some cooking headers have fun messing with it. 4Hi I have never encountered any problems shifting out or in while moving.
Larry Wall
Nov 19, 2014 04:13 PM
Randall's Truck
Feb 7, 2014 04:35 PM
lundman
6.7L Power Stroke Diesel
Feb 18, 2013 10:15 AM
htimst
Jan 12, 2011 08:07 PM
fordrose250
Feb 17, 2006 01:35 PM
