wiring a c4
Old Nov 29, 2006 | 09:06 PM
lightstar's Avatar
lightstar
wiring a c4
I have a 1974 -351w with a c4 trans in my 58 f100. the wires on the trans were all cut..where can I find a diagram to connect those. one is to keep theit from starting in all gears and goes to??? what are the others and where do the go??? Thank You
Old Nov 30, 2006 | 10:25 AM
Okiedokie's Avatar
Okiedokie
There are no electrical wires on a C4.
Old Nov 30, 2006 | 10:53 AM
mcdonaldm's Avatar
mcdonaldm
He is talking about the wires for the neutral safety switch and the backup lights.
if memory serves me right their should be 4 wires. 2 wires for the neutral safety and 2 for backup.
i don't have a wiring diagram handy (but any wiring diagram for any ford vehicle probably from 69 - early 80's will work as the switches were all pretty generic as far as function), but you can see what two wires are open in park and neutral and that is the neutral safety and gets wired in series with the start wires from your ignition switch.
and of course the backup wires will be open in reverse.
if you still require a wiring diagram, i will copy one for my 79 ford truck, it should be close enough to work.
rgds
Mike
Old Nov 30, 2006 | 10:59 AM
Okiedokie's Avatar
Okiedokie
Good thing my wife is not looking on, she would say "see, you don't read any better than you listen".
Steven Persinger
Feb 25, 2015 01:16 PM
J ballan
Jan 30, 2012 09:50 PM
daddy57
Jan 28, 2008 08:19 AM
keithredfirebird
Aug 10, 2006 09:56 PM
