Bank 2 sensor 2 wiring
Old Feb 25, 2015 | 12:00 PM
Steven Persinger's Avatar
Steven Persinger
The wire must have gotten caught around the front drive shaft as it is missing from the sensor forward. The sensor wire is all there, but I don't know where the missing wire went to going forward on the vehicle ( 2001 expedtion, 5.4, auto trans, 4x4) I cant replace(fix)until I find the other end.
Old Feb 25, 2015 | 12:06 PM
r2millers's Avatar
r2millers
Usually the heat resistant wire is already attached to the sensor and extends 3-4' max to the oblong connector. It shouldn't be too far up the drivetrain line to see. That connector doesn't disconnect easily by itself and the end of the wire, may still be connected.
Old Feb 25, 2015 | 01:00 PM
Steven Persinger
Sensor and plug are all there,+ about a foot of wire past the plug, but that is all.
Old Feb 25, 2015 | 01:16 PM
alloro's Avatar
alloro
The B2S2 wiring seems to be quite a bit back to have been damaged by the front drive shaft. You sure someone didn't unplug it, move it out of the way, and then forget about it?
IHateCommieCars
Feb 2, 2021 08:08 AM
d4j2s0
Feb 7, 2018 01:02 AM
dogg16
Bronco II
Aug 17, 2004 12:11 PM
rgillies1986
Jun 25, 2004 01:56 PM
