I'm at my buddy's shop right now and he's having problems troubleshooting a problem with his 2001 F250 XLT truck. The truck is a diesel, with a 6 speed standard and air conditioning. 176,000 mi on the clock.
His issue is this: The truck has an intermittent stumbe (sometimes stall). It's very random. Sometimes the check engine light will come on, sometime it wont. We've attached a snap-on scanner, and it shows no codes at all.
We spoke with Ford and we were told to check for some sort of loose bolt on the back of the fuel filter assembly. It's tight, with no leakage.
Just some more info... we've been enjoying a week of -14F temperatures. Don't know if this is contributing or not.
Any ideas? Neither one of us are diesel savvy either... might be part of the problem
I'll guess the Diesel fuel is starting to gel at those temps. Does he add any anti-gel to the fuel? Diesel Kleen in the white bottle would help if it's the fuel gelling.
Idle Air Control solenoid. I'm probobly out in left field.
Maybe another question too. If the CPS was bad, will you always get a code, never get a code or sometimes get a code when we read the codes with a scanner.
It might be the CPS going south, my truck has done this once in a while, just driving along, pull up at a stop light and Blagh, dead. Fires right back up though. I would at least get a spare to put in the glove box, just in case. I haven't changed mine yet but I am prepared. Also I don't think you get any code, I haven't seen one on mine, and from what I have read on here I don't think you get one. It has been said on here that to watch the RPM Gauge to see if there is any movement when you crank it, If not then it is a sign that the CPS is going bad, my gauge has never moved during cranking since I learned about it over a year ago, so I don't know. Just my .02.
Sometimes the CPS will set codes P0340, P0341, P0344 and sometimes not. It has to occur a certain number of time in a single drive cycle to set a code so when they are intermittant the code is not always set.
Could you be referring to the AIH or Air Intake Heater?
Well gents, the symptoms you are describing certainly sound like we need to have a look at the CPS sensor. We're trying to get the truck to stumble with the scanner on it to see if we get any codes, but who knows if it will act up. It's in a nice warm shop now.
Anyway, since everyone seems to agree that we might not get a code, I'm going to tell my buddy that he should probobly take a look at the CPS sensor. Clean the contact and check for work or frayed wiring to the sensor.
If all looks, good, should I tell him to buy one and try it? I know it sucks buying parts just on a whim, but what you guys are saying sure seems to be what the issue is
Hey, they're $50-60 on EBay. Most folks here have a spare. They suck. You cannot really test them aside from pulling them out and re-installing them or reseating and checking for obvious frays in wiring or a bad connection.
At worst, you will have eliminated the most likely culprit and can get on with the troubleshooting and have a spare. Best case, problem solved, and time to get another CPS to have on hand. It definately sounds like the CPS is faulty.
