351w versus 351w
Old Nov 29, 2006 | 11:22 AM
wifes65's Avatar
wifes65
351w versus 351w
I have a 351w from a 85 ford van, any difference than a 351w from a 85 car? Would the horsepower and torque be the same?
The motor came with carb.
the casting numbers read D9AE-6015-ED 15 for the block
E6TE 9425 CA intake manifold
E5AE CA cylinder heads
Old Nov 29, 2006 | 12:41 PM
Kemicalburns's Avatar
Kemicalburns
cam profiles might be different , heads are probably the same and not sure what intake differences there maybe. carbs could be different as well.
Old Nov 29, 2006 | 01:50 PM
Conanski's Avatar
Conanski
The differences would be very minimal. The car motor could be an HO if it came from a police cruiser, but even then the only difference is a slightly bigger cam and maybe a 4bbl. Either motor with a decent aftermarket cam would out muscle the other in stock trim, so you are basically at the same baseline regardless which block you start with.
Old Nov 29, 2006 | 02:43 PM
wifes65's Avatar
wifes65
thanks
thank you for the fast response.
PreciousOne
Sep 19, 2008 06:34 PM
thefnswits
Feb 29, 2008 11:47 AM
glruff
Delaware Chapter
Jun 23, 2007 02:40 AM
yellow78ford
Mar 23, 2007 08:18 AM
john_navarro
Escape & Escape Hybrid
Jul 9, 2006 07:15 PM
