Sponsored by: Real Truck
Headlights will not work on Low Beam
Old Nov 28, 2006 | 02:44 PM
georgiaford67's Avatar
georgiaford67
Fog lights work, and high beam works but low beam I have nothing.
I have went through the entire circuit.
1. I checked continuity through the main switch, the multi switch is working, I checked voltage at both and getting 12v(orange/grey). The drawings mention a relay but I have swapped around relays and the problem never moves. Fuses have been checked.
Is there some hidden circuit breakers,fuses or relays anywhere? I have been through the under hood distribution as well as the in cab. No luck.
Any help would be appreciated.
Thanks
REM
Old Nov 28, 2006 | 02:58 PM
Leader's Avatar
Leader
Try a new bulb. It wouldn't be the first time both headlights blew the low beams at the same time.
Old Nov 28, 2006 | 03:02 PM
georgiaford67
I looked at the bulbs and see both elements in tact and they both burn on bright, does something internal go bad in the bulb?
Old Nov 28, 2006 | 04:21 PM
captchas's Avatar
captchas
Guest
yes it's very possible try useing a ohm meter on the bulb to test it . as leader stated i also in my many years in dealer ship shops found both bad at one time.
Old Nov 28, 2006 | 04:28 PM
Leader's Avatar
Leader
Did you check voltage at the plug?
Old Nov 28, 2006 | 04:50 PM
jake00's Avatar
jake00
i had a light that burned out the low beam but not the hi beam
Old Dec 1, 2006 | 01:15 PM
georgiaford67
I went out to do some more checking yesterday and before I did I routinely flipped the light switch to on and whola they worked, flipped it about 3 or 4 more times no problem.I went out this morning and again "No low beam lights". I pulled the main switch back out and checked again and I am getting the continuity from the pins it's calling out for the switch, my question now is this, does the light switch unit also have the relays for park light/headlight built in or are they located elsewhere.
Old Dec 1, 2006 | 02:34 PM
PHWLEE's Avatar
PHWLEE
In had to pull out my switch when I wired my clearance lights and I didn't see any relays attached to the back. They must be elsewhere. Oh, that switch is a easy to take out.
90pioneer
May 9, 2015 11:44 AM
cabloom300
Aug 6, 2014 06:25 PM
aircropsinc
Dec 23, 2012 09:03 PM
JKnSD
1983 - 2012 Ranger & B-Series
Jul 29, 2011 05:04 PM
snowdog79
Electrical Systems/Wiring
Mar 19, 2011 12:26 AM
