Sponsored by: Auxito
Bigger Tire Size
Old Dec 1, 2006 | 01:04 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thanks for the info man! And Im glad you posted that link to DixonBros. I have been looking for a long travel kit for my F150 for a couple months now. A little pricey...but Im sure it's well worth it.
Old Dec 1, 2006 | 01:58 PM
drj777's Avatar
drj777
Talking
i think the owners name is chris - and hes REALLY nice...although the kit is not cheap - it IS the business in peformance!!
drj
Old Dec 1, 2006 | 02:37 PM
preppypyro's Avatar
preppypyro
Heh yeah performance and cheap dont usually go together well.
Old Dec 1, 2006 | 04:32 PM
drj777's Avatar
drj777
Talking
not unless youre talking about ghetto prostitutes!!!
drj
Old Dec 2, 2006 | 02:47 AM
Nightrain's Avatar
Nightrain
Glad I found this thread!!
I have a specific tire question...
I have a set of "5-fin" chrome 15" F-150 wheels that I think would look good on the 1998 F-150 SuperCab 4x4 that I'm looking at.
I want to run the biggest Maxxis Buckshots that I can on the truck without a lift of any kind.
On my current 1992 F-150 4x4, I have 32x11.50x15 Buckshot's, and they only rub the torsion bars when the wheels are cut fully to either side.
So, on those 15" wheels, what is the BIGGEST Buckshot that I can stuff under a factory-lifted '98 4x4 without rubbing?
Thanks!
Nightrain
Old Dec 2, 2006 | 02:56 AM
tdister's Avatar
tdister
Sorry if I'm misunderstanding your question. I can't answer the tire size question, but the wheels from a '92 will not bolt onto a 98. Different bolt pattern and mounting style. Sorry.
Old Dec 2, 2006 | 05:20 AM
rleyland's Avatar
rleyland
I have an 99 F150 and changed the tire to a different series tire. If I recall, the stock tires were 255/70. I changed them to a 265/75. Basically, the 265 is the treadwidth in millimeters and the 75 is the percentage of sidewall height to treadwidth.
In my example:
Before: 70% of 255 MM x 2 + rim diameter = total height
After: 75% of 265 MM X 2 + rim diameter = total height
Old Dec 2, 2006 | 10:03 AM
Nightrain's Avatar
Nightrain
Well dad-gum... lol.
I figured they would, but oh well. So much fer that.
Thanks fer yer reply.
Nightrain
Old Dec 2, 2006 | 03:12 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Nightrain
Even if they did have the right bolt pattern, a 15" wheel will not clear the brakes.
But, to answer your other question, a 285/75/16 is just about the biggest tire you can fit under a bone stock '97-'03 4x4.
For some reason...I can fit 34's on my '97 without rubbing.
Old Dec 3, 2006 | 01:26 AM
Nightrain's Avatar
Nightrain
Whew, I didn't realize there was that much difference.
Thanks fer the heads up!!
Nightrain
Old Dec 4, 2006 | 12:01 AM
preppypyro's Avatar
preppypyro
Hey atc crazy, what size are your 34's? Is that a 315/75r16?
Old Dec 5, 2006 | 11:05 PM
Nightrain's Avatar
Nightrain
Originally Posted by kanarman
I have some 33X11.50X16 Bridgestone Dueler Revo A/T mounted on Mickey Thompson Classic II
Those 33x11.50x16's that you have...
Did they ever rub any when they were on your truck, especially with the wheels turned all the way in either direction?
Also, what was the width of your Mickey Thompson wheels?
That's the size of tire that I'd like to go with when I finally get one of these trucks...
Thanks, bud!
Nightrain
Old Dec 7, 2006 | 11:07 AM
  #28
FordTrucksKickGM's Avatar
FordTrucksKickGM
Ok back to tire talk. Anyone run 285/75/16's on stock 16x7 rims?
Old Dec 7, 2006 | 11:09 AM
  #29
preppypyro's Avatar
preppypyro
I had stock 285's on my stock rims before i got my aftermarket ones. They fit fine.
bismic
Mar 9, 2022 09:20 AM
07EXPYEL
Jun 7, 2016 11:51 AM
greenshovel
Dec 5, 2015 12:35 PM
bismic
Aug 10, 2015 10:35 AM
Ford Fx4
2004 - 2008 F150
17
May 14, 2007 04:28 PM
