Which new engine?
Old Nov 28, 2006 | 01:17 PM
GWall's Avatar
GWall
Which new engine?
After nearly 320,000 miles it looks like I am going to have to replace the engine in my '93 F150 5.0. Almost everybody offers "remanufactured" engines for these things. Are some better than others or are they all pretty much the same?
Old Nov 28, 2006 | 01:37 PM
brian.taylor's Avatar
brian.taylor
I've heard good things about Jasper Engines, no personal experience though
Old Nov 28, 2006 | 02:37 PM
Kemicalburns's Avatar
Kemicalburns
are you stuck on the 5.0? what do you use your rig for? if you up for options you might consider a 5.8 swap if towing and work are more your game.
Old Nov 28, 2006 | 02:51 PM
GWall's Avatar
GWall
It is just for highway driving to and from work. Occassionally I pull a utility trailer but no heavy hauling.
Old Nov 28, 2006 | 07:03 PM
mikeyswood's Avatar
mikeyswood
It sounds like the 5.0 will work for you, but you will still want to evaluate the 5.8.
Rhinoengine.com almost made me commit, but I decided to build my own. Jasper has an imperfect reputation around here. Check with local shops and do your homework. You should be able to get one put in for $1700ish.
Mike
Old Nov 28, 2006 | 07:04 PM
frederic's Avatar
frederic
If you have a 5.0L now, swapping in a 5.0L longblock is the path of least resistance. Remove old engine, remove tinware and accessories, install tinwear (and gaskets) and accessories on new engine, drop new engine in, put old engine in plastic "core" container, call shipping company.
Another option, depending on the junkyards near you, sometimes you can find a running complete engine for a reasonable price. Around here, one particular junkyard charges $300 for "small" engines, and $400 for "large" engines, and $500 for "really large" engines. These categories are subjective and depends on the mood of the guy in the booth that day. But, the prices aren't so bad and once in a while if you buy other stuff you can negotiate. Two summers ago I got an EFI 460 with 89K with everything but an alternator for $350.
If you want a reman engine, Jasper is fine as is Ford remans, and the Ford Remans (at least over here in NJ) seem to be priced reasonably similar to Jasper. Maybe $100 more, but the warranty is better from what I could tell.
If you want to swap to the 5.8L, obviously a junkyard engine is the way to go as you get all the tinware and bracketry, efi harness, and so forth, that may not plug "right in" from your 5.0L.
Old Nov 28, 2006 | 07:15 PM
wizzard351's Avatar
wizzard351
i had ford install a reman 302 in my 92.they also replaced exauhst manafolds oilpan,both gas tanks,radiator,injecters and countless other things i cant remember.they had it for 2 1/2 weeks and the whole bill was around 4800 i know its alot but heck this is the first one in 20 years i paid someone to do a swap heck i usualy do them my self. i wouldnt use any thing but a ford reman or one from a local builder.i put a 360dodge in a truck for a neighbor and it had an asembled in mexico sticker on it and come from oreileys lasted 14k just out of warenty.we tore it down to mabe patch it up and all 8 cyl had sleaves and crank was 30/30 basicaly scrap iron for 1400bucks.
Old Nov 28, 2006 | 07:32 PM
denny 280's Avatar
denny 280
When I did mine I had a local engine builder that has a good reputation build mine. He did me a long block for 980.00$. 7yr 70,000 mile warrnty same as the chain stores give. Kragen wanted 1700$ for the same long block with the same warrnty. He builds his own in his own machine shop. No regrets I have 12,000 miles on it now and its a better motor than the truck had in it new.
