i need a tach!
Old Nov 27, 2006 | 12:46 PM
5.0Torx's Avatar
5.0Torx
i need a tach!
hey all, i was wondering what kind of aftermarket tachs will work for my 83 F-250 with the 300. I dont like the look of the factory tach, and i dont want to do all the work to switch pods. Im fine with just boltin an aftermarket one onto the dash or column. But i was wondering what tachs will work, and how hard it is to wire up.
TIA!
Old Nov 27, 2006 | 12:59 PM
Redneck1465's Avatar
Redneck1465
I cant think of any tach that wouldnt work. Just get a tack and run the wires. They prolly have directions on how to install it in the box.
Old Nov 27, 2006 | 01:01 PM
Redneck1465
Forgot to say that there are usually only three wires, one for a ground-one for power-and one that runs to the engine to determine the RPMs.
Old Nov 27, 2006 | 02:23 PM
TWULFF44's Avatar
TWULFF44
checkout summitracing.com . they have alot of great tachs. They are usually a three wire hookup like previously mentioned.
Old Nov 27, 2006 | 02:42 PM
5.0Torx's Avatar
5.0Torx
sorry for my confusion, but i would also like to know if i could hook up "just any old tach" to my 1993 mustang, in the event that i get in an accident with the truck or decide to sell it. Would the tach input just be the negative end of the coil terminal?
can i get a link of a popular tach that will work?
Old Nov 27, 2006 | 10:26 PM
VirginiaWiFinder's Avatar
VirginiaWiFinder
It is all about personal preferance. Big, small, black, white, chrome, gold, shift light, no shift light. Plus you can spend anywhere from $25 to $500...(no kidding there). Take a stroll through an Autozone/PepBoys store and take a gander. As mentioned Summit Racing.com has plenty in different price ranges. Also as mentioned most (simple) aftermarket tachs are easy to install. One wire to the ground, one wire to the coil and one wire to turn on the backlight so see at night. It would be easily swapped into another vehicle. As for difficuilty to install...I'd have to say harder than changing a flat but less hard than installing a radio.
Shop around...stay and stay within your budget. You won't need a fancy tach unless you are taking your truck to the drag strip on a regular basis....They all tell engine speed. Don't forget...there is always the ever popular eBay.
My 2 cents.
Old Nov 27, 2006 | 11:05 PM
5.0Torx's Avatar
5.0Torx
thanks. would the Sun Pro 7901 or 7903 on summitracing.com work?
Old Nov 28, 2006 | 01:13 AM
Redneck1465
Any tach will work, its just your preference on what style you want for your car/truck.
Old Nov 28, 2006 | 07:50 PM
VirginiaWiFinder
Sure would...I'd also check a national auto parts place too...Most carry SunPro and they might be a bit cheaper.
