problems with climate control unit
Old Jul 17, 2006 | 09:28 PM
jlalanas's Avatar
jlalanas
Cool problems with climate control unit
I am experiencing problems with my electronic climate control unit in my 2004 f150 lariat. Worked this morning and when I got in the car after work, went back out 45mins later and the climate control unit goes on and off itself every 10 secs. If I turn the unit off, the lights in the unit will do the same.
I should note that I just installed a PIE unit to hook up my satelite radio and hard wired the power to the accessory plug in the dash. Everything worked fine after the install which was three days ago.
I also have a Edge Evolution hooked up.
Curious if either of these things are related to my climate control issue. Can anyone help or offer some suggestions before I call the dealer.
Thanks.
Old Jul 19, 2006 | 05:27 AM
DJR 17's Avatar
DJR 17
I think I would pull everything apart and check all the connections.
Old Jul 19, 2006 | 07:51 AM
jlalanas's Avatar
jlalanas
After posting this, I found another thread that suggested unplugging both plugs of the climate control unit and then plugging them back in. I did that and it is working again. Also read that people disconected the neg bat terminal which does the same thing.
I'll keep an eye on it, and if it acts up again it's going back to the dealer. I'm at 33,500mi and as you all now, the warranty is up at 36,000.
Thanks.
racin
1997 - 2003 F150
Jun 22, 2016 05:30 PM
David7.3
Jul 1, 2014 10:56 PM
5.0 Heaven
Jun 24, 2013 06:49 AM
mgood777
1997 - 2003 F150
Aug 2, 2010 10:51 PM
BCClements
2004 - 2008 F150
May 23, 2007 08:25 AM
