E4OD Which fluid??
Old Nov 27, 2006 | 04:33 AM
holland501's Avatar
holland501
E4OD Which fluid??
I know I should use the search function but for some reason I'm not allowed. Again!
My manual says use Mercon, then in parentheses It says DexronII. I'm sure I have seen other types mentioned as well in the threads here.
If anyone can shed some light on this, I would appreciate it. I'm planning on a complete drain, trans and converter, so I don't want to buy a couple of cases of the wrong stuff. Thanks.
Old Nov 27, 2006 | 07:07 AM
Casey's Avatar
Casey
The manual says MERCON. You won't find a MERCON fluid that doesn't also say DEXRON III. Those two specs are almost identical, so any fluid that meets one, meets the other, too.
In mid-2007 Ford will stop licensing MERCON. It will go away. They changed the formulation of MERCON V recently so that it is compatible with the E4OD/4R100. That's what you will have to use in the future.
codybear
Nov 26, 2012 02:05 PM
wheelhoppin67
19
Apr 14, 2009 11:01 PM
debestuss
30
Nov 22, 2004 07:20 PM
meangenejr
Sep 6, 2004 01:43 PM
