Power to fuel pump problems
Old Nov 26, 2006 | 07:43 PM
ssamduran's Avatar
ssamduran
Exclamation Power to fuel pump problems
<TABLE class="" style="MARGIN-TOP: 10px" cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=table-left rowSpan=2></TD><TD class=bg-icon-question><!-- List Question -->Is there an in-line fuse on the frame rail to fuel pumps?
My vehicle is a 1990 F150 s-cab 5.0L V8 with dual in tanks. I am trying to figure out if there is an inline fuse because I found an open circuit in a wire behind the fuel tank selector switch. I fixed it and now the truck just cranks over, nothing more. So I then did a test on running the fuel pump continuously with the engine off by grounding the fuel pump on the DLC connector. This test also failed. I also checked the inertia switch it turned out to be fine. I grabbed a volt meter and checked for voltage at the fuel pumps. I got nothing there. I am out of ideas. Any opinions or ideas greatly appriciated.Thanks.
</TD></TR></TBODY></TABLE>
Old Nov 26, 2006 | 08:12 PM
subford's Avatar
subford
The only fusing for the fuel pumps is the fuse link at the starter solenoid.
Here is a diagram of you fuel electrical system.
http://i54.photobucket.com/albums/g9...el1990F150.jpg
Old Nov 26, 2006 | 08:17 PM
ChurchBuilder's Avatar
ChurchBuilder
I just had the same problem. I replaced the fuel pump relay and now it works. When I grounded the test I heard the relay click but no power. It is the green relay under the hood.
luckypunk
Jun 13, 2015 05:59 PM
EALightingSolutions
2009 - 2014 F150
May 17, 2015 09:45 PM
AbandonedBronco
Mar 3, 2015 08:10 PM
Garden Spyder
22
Jul 13, 2014 09:38 PM
greenheads
May 30, 2014 07:57 PM
