alternator
my truck now has 190,000 miles and is on the stock alternator and the batteries are ac delco 650cca and were bought on 10/1/12. i have put about 50,000 miles since then.
I just wanted to make sure you agreed it is my alternator before i order one.
also i am planning on putting on a warn 16.5ti winch in the next few weeks so its not a bad time to upgrade both alternator and batteries.
for batteries i am looking at the platinum 900cca from sears but looking for input for the alternator. here are the amp draws for the pulling weights
any thoughts???
<table cellSpacing="0" width="100%"><tbody><tr><td class="title3" colSpan="4">12V DC PERFORMANCE SPECS</td></tr><tr><td width="25%">Line Pull
Lbs.(Kgs.)</td><td width="25%">Line Speed
FT./min(M/min.)</td><td width="25%">Motor
Current</td><td width="25%">Pull by layer
layer/Lbs(Kgs.)</td></tr><tr class="altrow" height="18"><td>0</td><td>23.6(7.20)</td><td>68 amps</td><td>1/16500(7484)</td></tr><tr height="18"><td>2000(907)</td><td>12.07(3.68)</td><td>138 amps</td><td>2/15279(6930)</td></tr><tr class="altrow" height="18"><td>4000(1814)</td><td>9.22(2.81)</td><td>189 amps</td><td>3/12672(5748)</td></tr><tr height="18"><td>6000(2721)</td><td>7.37(2.25)</td><td>240 amps</td><td>4/10824(4910)</td></tr><tr class="altrow" height="18"><td>8000(3628)</td><td>6.08(1.85)</td><td>291 amps</td><td></td></tr><tr height="18"><td>10000(4536)</td><td>5.12(1.56)</td><td>342 amps</td><td></td></tr><tr class="altrow" height="18"><td>12000(5443)</td><td>4.40(1.34)</td><td>393 amps</td><td></td></tr><tr height="18"><td>14000(6350)</td><td>3.86(1.18)</td><td>444 amps</td><td></td></tr><tr class="altrow" height="18"><td>16000(7257)</td><td>3.38(1.03)</td><td>494 amps</td><td></td></tr><tr height="18"><td>16500(7484)</td><td>3.24(0.99)</td><td>507 amps</td></tr></tbody></table>
Lowest you want is a 140a, and thats just for basic. If you have any goodies you should go bigger
Damn, that winch pulls some amps. What is the most weight you think you'd have to pull with it...8k?
I've always had winches on everthing i own but i wasn't planning on putting one on this truck because i try to stay out of the mud. however i frequently need one and have to either get my old truck or use chains to move trees or anything else. also the other day i burried my truck up behind the house and it ended up taking my tractor with a warn 9000ti and another truck with a warn m12000 to pull me out. neither would do it on their own. so i figure go ahead with the 16.5 and have it for another 40yrs.
thanks for the help so far with DC power. I was looking at their 270xp as we speek. does anybody know how much it is from Ed at FICM repair? any pros or cons? i would rather not spend the extra 200 for the 320.
