Tire balancing
Old Nov 26, 2006 | 04:15 PM
stevenw's Avatar
stevenw
Tire balancing
I have a 05 screw 21000 miles and about ready for tires already. No abnormal uneven wear, just tread is very low. When I get new tires what kind of balancing should I make sure they do? TIA
Old Nov 26, 2006 | 05:06 PM
04F150SC's Avatar
04F150SC
Hmm, I wonder why the tires went so fast on the first set. Whatever you do, make sure you have them do some good balancing.
Old Nov 26, 2006 | 07:11 PM
GlennJ's Avatar
GlennJ
Road force balancing is the best but is also the most expensive. I'd probably go with the usual 'spin' or dynamic balance first and only go the force balance route if there were problems. If you check the back of the car magazines you will see that outfits like The Tire rack road force balance all their tires. The bigger the rim size the more critical it is.
Old Nov 26, 2006 | 08:36 PM
EnergizerBunny69's Avatar
EnergizerBunny69
21,000 miles ? I just changed my original set. I had 59,000+ on them when I purchased my new set. I probably could have gone farther if I would have kept up better with the balances and rotations.
Old Nov 26, 2006 | 09:00 PM
johntucker09's Avatar
johntucker09
I originally had the conti's on mine, at 13 thou i was getting a new set of michelins put on, the conti's looked really bad...
Old Nov 26, 2006 | 09:26 PM
phatpony's Avatar
phatpony
I've got almost 40K on my original Michelins with atleast another 10K to go on them. That's what I'll put back on too. You need to figure out why those tires went bad at 21K. Rotating them is real important. Do it atleast every other oil change. I do my own rotating, only takes about half an hour with an impact wrench (to remove only) and 4 jack stands.
Old Nov 26, 2006 | 09:29 PM
johntucker09
i know that in my case, i rotated at 5 and at 10, one morning i went out and looked at them, my back tires had chunks missing out of them...
Old Nov 26, 2006 | 09:40 PM
Firemut30's Avatar
Firemut30
Did you criss-cross them(left front to right rear,right front to left rear)? I don't think they do that anymore, that is what I have heard can cause chunking.
Old Nov 26, 2006 | 09:43 PM
thebiga's Avatar
thebiga
I bought a 2005. About 6 months later they sent me a 50k warranty sticker to put over the warranty page in my owners manual that originally stated 30k. Did anyone else get their tire warranty extended? I wonder if I have to get them rotated at their service shop if I ever did have a problem?
Old Nov 27, 2006 | 05:32 AM
stevenw's Avatar
stevenw
Thanks for replies all. yes had them criss-crossed rotated every 5000 miles by dealer. Thet are the Continentals. Think the warranty covers them?
Old Nov 27, 2006 | 05:44 AM
phatpony's Avatar
phatpony
My owners manual says to move the back ones straight forward, and criss-cross the front to the back. I thought they quit doing that too. But I want to make sure I do everything by the book.
Old Nov 27, 2006 | 06:04 AM
wildcard30's Avatar
wildcard30
Check with the dealer. The continentals are covered for pre-mature wear. I had mine replaced for a wear/vibration problem at 5,000 miles.
Old Nov 27, 2006 | 07:09 AM
EBTDM's Avatar
EBTDM
Cheap tires cause all sorts of problems. They are not worth the effort you put into them. Throw the warranty away and go buy yourself a good set of tires. You paid thousands of dollars for your truck, what is a few hundred for tires and peace of mind?
Old Nov 27, 2006 | 11:38 AM
stevenw's Avatar
stevenw
Very true. I was thinking more of a credit towards better set.
Old Nov 27, 2006 | 01:40 PM
zag's Avatar
zag
I have been criss crossing the tires on 5000miles rotation periods for quite a few years. No problems and very good wear on the tires.
