Inline 6 to Inline 6 advice
Old Nov 26, 2006 | 01:41 PM
icepanl's Avatar
icepanl
Hey Guys,
Can you help me out here?
I have a '65 Ford F-100 with a 240 I6 1bbl. What I would like to do is replace it with a later model 300 I6.
Q: Is there a later model I6 that uses the same motor mount location as my original that I can just drop into my truck. I really don't want to have to redo motor mounts.
Q: Does that later model engine come with, or have the ability, to have an automatic tranny connected. I would really like to have an automatic that has OD for fuel mileage.
Thank You,
Max
Old Nov 26, 2006 | 02:01 PM
jowilker's Avatar
jowilker
icepanl, Welcome to FTE The nations #1 Ford truck stop for tech support.
Have you thought about rebuilding your engine with a 300 rotating assembly? Same engine different stroke.
You should be able to bolt a AOD to the back of it.
John
Old Nov 26, 2006 | 02:17 PM
icepanl's Avatar
icepanl
A mechanic friend of mine said he could rebuild my 240 I6 to a 300 I6, but he said he thought there was no automatic that would mount up to it. Being a '65, it seems to be one of those inbetween (oddball) Fords.
Are you saying I can rebuild this original engine and then mount an AOD to it? Will the holes all be inline?
Max
Old Nov 26, 2006 | 02:26 PM
icepanl's Avatar
icepanl
If I got the tranny, is there anything else I would need to get?
Old Nov 26, 2006 | 04:20 PM
Haaser's Avatar
Haaser
An AOD wll fit from either a small block 302 or 351 or another newer I-6 such as somthing in the 1990's. You will also need the bellhousing and the flexplate.
Old Nov 26, 2006 | 05:50 PM
312's Avatar
312
a 300 and aod will be more or less a drop in. i put a 300 crank in a 240 before.you need crank rods and pistons.if you can get a good 300 why bother.240 and 300 have same bell.
Old Nov 27, 2006 | 06:55 AM
63redtudor's Avatar
63redtudor
The 240 & 300 block are almost identical & like 312 says, you can make a 240 into a 300 (or I suppose, a 300 into a 240). The main differences you'll find with a newer 300, is additional mounting bosses on the block & head. The 240/300 bellhousing is the same as the SBF, so any transmission that works with a 302/351 will bolt right up. However, the flexplate needs to be for a 300 as the V8s are externally ballanced while the 300 (all I6s actually) are internally ballanced. Should be able to pick one up fairly easy, if not, take a 302 flexplate to a machine shop & have them machine the weight off. You didn't say if you were planning on running a carb or EFI. You might was to consider running a carb & getting a '86 or earlier engine. The '87 & later 300s were EFI & have a different head design, if you run a carb on these engines you might need to re-curve the distributor. Additionally, or, adapting the EFI to an older vehicle can be more work that its worth. There are a few who have done it though, ask on the inline six sectionl. I've got some info about the 240/300 series engines on my site: http://www.geocities.com/edwins63/.
Hope all of this helps.
Edwin
Old Nov 27, 2006 | 07:50 AM
chadwickma's Avatar
chadwickma
You will also need to make sure your radiator is setup for an automatic transmission and you will need cooling lines for it. Look along the bottom edge of your radiatior to make sure it has two currently plugged connectors for coolant lines. It you don not have them, you will also need to replace the radiator.
Old Nov 30, 2006 | 09:00 AM
icepanl's Avatar
icepanl
Hey guys,
I appreciate the info very much. Keep it coming!
And to replace that radiator, what model car/truck should I get it from?
The reason I was thinking of a later 300 I6 is that I continually keep having oil leaks around the push rod cover on the drivers side of the engine. The thin metal cover just does'nt do the job and I have'nt found anyplace that makes a billet cover. I've seen pics of later model 300's that don't have the push rod/lifter access on the side of the engine.
If I'm wrong, can someone tell me where I can purchase matching billet covers?
Thanks Much,
Max
Old Nov 30, 2006 | 05:14 PM
Baer's Avatar
Baer
Instead of replacing radiator to one for auto, just go get a transmission cooler, they bolt right in front of the radiator. Much cheaper also.
Old Dec 2, 2006 | 01:53 AM
paulnied's Avatar
paulnied
You better take another look at a late model 300, because they all have pushrod/lifter side covers - necessary to get the lifters out. The key to the side covers not leaking is not to overtighten them; they want very little pressure or they will leak. I just redid mine with new gasket and they're dry. You may have other reasons to want a 300, but this isn't one of them.
Old Dec 2, 2006 | 04:31 AM
jowilker's Avatar
jowilker
paulnied Welcome to FTE and the 61-66 forum.
Hope to see ya around.
John
blowhole
Sep 20, 2023 10:55 PM
MessengerII
Apr 2, 2009 11:57 AM
cal30_sniper
May 20, 2008 03:59 PM
goodwrench
Oil & Lubrication
Jan 4, 2007 04:59 PM
vernonater
1983 - 2012 Ranger & B-Series
Nov 28, 2003 09:55 PM
