#7 cyl low compression -- can't pass smog :-(
Originally Posted by packlet
why would oil pressure be at risk running on 7 cylinders?
The lifter should stay in place, but watch the oil pressure to be certain.
hey, it worked! i removed the driver's side valve cover and took off the intake rocker and pushrod. let her warm up and went to the smog station. the guy had to run it a few times, but eventually got a passable reading of 130 ppm for HC. maybe he felt sorry for me and somehow rigged it, but it's done at least and i can fix the real problem (prolly a burnt exhaust valve) when i can afford it. thanx all for your tips and support!
KevinsMom
Bronco II
08-27-2014 11:53 AM
matt1987
08-02-2013 06:45 PM
