Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Bandsaw Base
Old Nov 29, 2006 | 06:45 AM
frederic's Avatar
frederic
Free fuel is "okay". I've gotten pretty good at siphoning from cars that obviously ran "recently" rather than anything that's left there overnight. The county's PD drops off abandoned/impounded cars every night which have a 30 day minimum sit period. If there are charges filed against the owner, then the car would have been impounded for the duration of the case. So sometimes the gas isn't very good. I have an inline filter before it goes into my tank(s), so at least sediment and garbage doesn't go through.
In fact it's probably time to change that filter. For a cord I use speaker wire and a molex connector. Underneath my bed under the front filler tube is a permanently powered mating molex connector I added for this purpose.
The owner of the tranny shop is retiring, and it's not a chain. He's going to let me know by close of business today whether he's selling it to me or not. He said there was one offer slightly lower than mine, and one quite a bit higher than mine, though the higher offer was from a guy who is going to "chase my employees away" to use his words.
Cool idea on the wix. This shop does mostly rebuilds for service stations and other car repair places, and very little retail. They only have two bays, one of which is clogged with boxes and junk, the other has the owners car sitting in it. There is another two bay equivelent of space with metal desks, rollaways, and so forth, where the employees rebuild trannies. While I was looking around a few transmissions came in through the front door right through the small retail counter area to get into the shop. This explains why the grey tiled floor in that area was sopping wet, grossly stained, and a mess lol.
Old Nov 29, 2006 | 02:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Good luck on the shop!
Ford required the filter when servicing the E4OD etc but of course everyone wanted to go low buck, skip the filter install, and then tranny failures result. ALL of the newer electronic controlled trannies could use one of those filters. They are made for PS systems also and I use them. Some tranny shops won't install them because nobody services them. They are pressure relieved so when they fill up they bypass.
frederic
16
Apr 29, 2007 01:39 AM
frederic
Garage & Workshop
93
Jul 26, 2006 10:59 PM
frederic
Garage & Workshop
32
Mar 30, 2006 06:54 AM
frederic
New Jersey Chapter
Sep 22, 2005 07:58 PM
