Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
DIY Welding Cart
Old Mar 22, 2006 | 08:30 PM
frederic's Avatar
frederic
DIY Welding Cart
Pile of "Scrap" stuff, mostly from recent dumpster diving (except the casters and the drawer slides... though came off another project):
hack things up and build a base:
http://frederic.midimonkey.com/yard/...t/IM001641.JPG
Weld on some uprights:
http://frederic.midimonkey.com/yard/...t/IM001643.JPG
And viola, near-instant welding cart:
http://frederic.midimonkey.com/yard/...t/IM001645.JPG
I still have some more work to do... but this is how far I got today. Have to do the following still:
1. Weld on the caster pads, which are cut, drilled and tapped.
2. Install the chain attachment points to retain the gas cylinder.
3. Install a push/pull handle.
4. Wire up the 240V twistlock outlets, the main power switch, and attach the 30' cord with a twistlock on that end as well.
5. Prime and paint!
I am pleased especially considering I eyeballed it. It's actually fairly square!
Old Mar 23, 2006 | 08:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
not bad for a monkey welder.
Old Mar 23, 2006 | 10:05 AM
frederic's Avatar
frederic
Not to bad for nearly free either! It will be much nicer once I put on the rest of the pieces, most of which I've cut.
What's nice is the steel from the retail displays, had some quick-on/quick-off hooks so since there will be some of that left over, I'll weld a few on the sides so I can add/remove hooks for the welding cables and ground clamps.
Old Mar 24, 2006 | 10:08 AM
MichSandSquid's Avatar
MichSandSquid
Where do you go to dumpster dive for metal like that?
Old Mar 24, 2006 | 01:03 PM
tjc transport
i ain't rite
that is a secret that he only shares with people that don't like metal.
Old Mar 24, 2006 | 03:26 PM
frederic's Avatar
frederic
All sorts of places. Office Max, Staples, and of the larger retail stores (in strip malls where you have easy access to dumpsters behind the buildings) sometimes throw out retail displays which are generally made of mild and stainless steel. Sometimes painted, powdercoated etc. Beggers can't be choosy. The angle iron was in the dumpster behind the new Lowes near me. I think they chucked it because it was a bit rusty.
Anyway, made some more progress today.
Cut the caster "feet" (which is a pain BTW when your last 10" chop saw blade is only 6" ):
http://frederic.midimonkey.com/yard/...t/IM001646.JPG
Then welded on the feet and the back brace:
http://frederic.midimonkey.com/yard/...t/IM001648.JPG
Then cold galvanized the entire thing. For tools, carts, racks and things that I more than likely use outside the garage, haul to friend's houses and so on, I use a spray-on galvanizing product I get from Ace Hardware in place of rustoleum or store brand primer. It's not true galvanizing which is an electric process, but it does stick really good and can survive some bumping around as compared to regular primer. For $1 more a can why the heck not.
http://frederic.midimonkey.com/yard/...t/IM001649.JPG
Assuming it's not raining tomorrow, I'll be painting it blue to match my engine run stand if I have enough paint left in the last can. If not, I have four cans of a grotesque red I can use instead
Oh, crap, I forgot to weld on the handle. Dammit!
Old Mar 24, 2006 | 07:36 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Nice work! Great photo essay too! I like to use that cold galvanizing primer on my welding projects too. Careful when you weld the handle on. The fumes from cold galv. may not be as bad as electo galv. but I don't want to find out either way.
Scott
Old Mar 25, 2006 | 09:29 AM
frederic's Avatar
frederic
Turns out I have much more welding to do. I was excited that I was "almost done" and forget not only to weld on the handle, but the top part that I'd chain the bottle too, which the handle attaches to. ooooops!
And you're right Scott, i will be absolutely careful welding with those fumes. I've done a ton of work with galvanized and the fumes are quite nasty.
And... why I made a "back breather". This device is very simple actually.... it's a diver's snorkle I got on ebay, and hacked the length down with a hack saw. Then slipped over a very soft, clear flexible 3/4" "aquarium" tubing, which goes down from the hacked up snorkel, around my side to my back just above my belt, to a body shop canister filter which I made a simple brass fitting to screw on the canister filter, and hose clamp the tubing. I clip that to my belt, and put my shirt over it, and while welding I breath air from behind me, through the canister and reasonably through my shirt. I made this not specifically because of galvanized metal, but rather I use flux-core welding wire and the smoke is rather incredible and I didn't want to breath the flux fumes.
If you make one of these (which costs almost nothing, except for the canister filter), since it's on your back part of your belt, just don't eat pork and beans before working
Old Mar 25, 2006 | 11:09 AM
Torque1st's Avatar
Torque1st
Posting Legend
Genius at work!!!
While you are working on the handle...
Don't forget the cabinet or drawers for the breathing apparatus, gloves, helmet, cap, leathers, chippers/hammers, lenses, chalk, liners, tips, pliers, tape, coppers, etc.
Make sure you have a place for that rod holder or just a place to put a few rods.
Also make that can holder for the tip spray etc, and the holder for your framing square. Those magnetic squares will take care of themselves and of course you need a place to put a few clamps, vise grips etc.
Are you sure those casters are going to be big enuf?
That cold galvanizing paint is just zinc rich paint so it will be bad just like regular galvanized just slightly less so...
Old Mar 25, 2006 | 01:58 PM
frederic's Avatar
frederic
Originally Posted by Torque1st
Genius at work!!!
Thank you. I generally refer to myself as a tool-happy monkey.
All of that stuff is in my big mechanic's chest, in the bottom right hand drawer. I may have to revisit that, as if this rig is as portable as I intend, having the accessories on the cart will make it that much more convienent. Great idea. There is enough room above the plasma cutter (bottom unit) and the top shelf for the mig welder, to put say, a 4" or 5" high drawer. I have the slides in the junk pile as you might have noticed.
Also good ideas. BTW, for "tip spray" and "slag spray" and "welding spray" I use brake cleaner and pam cooking spray. Both work well and are dirt cheeeeeeeep.
Big as far as diameter, I think so. Big as far as load capacity, absolutely. Each caster is rated for 500lbs. Absolute gross overkill. These were the casters that were on the workbench I gave to TJC Tom, the workbench I rebuilt engines on as well as built sections of tubular chassis'.
It's nasty to paint over too, as I discovered today.
Old Mar 25, 2006 | 04:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
I always derate casters by at least 50% if you want to have them live. I think they rate those things with a straight down force and rate them at the point at which they collapse. They sure won't roll or make it over a grain of sand at rated capacity. Of course there are some industrial caster companies that do a better rating job. My Miller AC/DC stick welder has a pair of small lawnmower wheels on it with a 1/2" shaft.
tjc transport
i ain't rite
well, i can see one very important thing you forgot. where is the coffee cup holder????
as brother homer would say,DOH!!!!
Old Mar 27, 2006 | 05:43 AM
frederic's Avatar
frederic
I had just enough red paint for this. So it's now red. Caster's are on, and it rolls around very nicely.
I fabricated the handle already, and I'm thinking maybe I'll bolt it on as not to grind off paint and galvanized primer underneath, and have it done in less than an hour. Drilling four holes is quicker than grinding, cutting, setting up the welder, and so on.
Then I guess I have to go back to garage cleaning
Old Mar 27, 2006 | 05:28 PM
frederic's Avatar
frederic
Installed the handle today. Decided bolts suck and welded it on instead.
Old Mar 27, 2006 | 06:22 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
That means there are two more Safeway carts in this world without their wheels. What will the homeless use, shame on you.
Hey it looks great and functions.
.....=o&o>.....
