computer location and identification
Old Nov 25, 2006 | 09:01 PM
rsavagebob's Avatar
rsavagebob
I've just bought a 2004 f150 4x4 4.6L and it has a keyless entry system. I understand that I can get the key code from the computer cover. Is this correct? I've looked on the passenger side under the glove box to the right side and I see fuses and relays and where I think the computer would be, but no cover and no numbers. Can anyone help? Thanks
Old Nov 25, 2006 | 10:15 PM
ohboy44's Avatar
ohboy44
If it's a Super cab or crew cab it's behind the back seat. If it's a reg cab it's behind the LR trim panel.
Old Nov 26, 2006 | 02:06 PM
rsavagebob's Avatar
rsavagebob
I appreciate the info on the computer. I found a box says Motorola pcm on the firewall passenger side in engine compartment. Any chance that is it?
Old Nov 26, 2006 | 02:17 PM
yoheidiho's Avatar
yoheidiho
The Motorola box on the firewall is the truck's computer. You can find the keyless entry code where ohboy44 indicated.
Old Nov 26, 2006 | 03:32 PM
rsavagebob's Avatar
rsavagebob
I don't mean to be so out of it, but this truck has no back seat, is a 4 door with about 18" behind the seat. On the passenger side rear is a compartment for the jack, nothing on the driver's side but a full panel that goes across the back.
Sounds like I need to pull that entire panel to get into the corner.
Thanks for all your help.
Old Nov 26, 2006 | 03:35 PM
Cavtrooper06's Avatar
Cavtrooper06
Sounds like your truck is a regular cab, then like ohboy44 stated, its behind the left rear trim panel.
Otherwise on a SuperCrew or SuperCab its located behind the rear seatback.
Old Nov 26, 2006 | 04:40 PM
rsavagebob's Avatar
rsavagebob
thanks, I'll tear into it and see if I can find the computer. Thanks for your help.
Old Nov 26, 2006 | 05:41 PM
HomerWinzlow's Avatar
HomerWinzlow
Does it have a factory keypad on the door? That is the only reason you would need a code and I dont recall a keypad on any standard cab truck. If it is a stick on keypad it is a dealer installed pad and has a keycode of its own, not the one on the module.
Old Nov 26, 2006 | 08:17 PM
cub129's Avatar
cub129
Check and see if there is a plastic card in the owners manual wallet that has the keyless entry code (for the touch pad on the door ) printed on it. My '04 and '06 Screws both had the card in the manual wallet.
sleddog
19
Dec 31, 2010 10:15 PM
frieknet
Computer Chips & Tuners
Dec 27, 2003 08:41 PM
szepj1
Jan 4, 2002 11:06 AM
szepj1
Dec 12, 2001 04:32 PM
szepj1
Nov 8, 2001 11:25 PM
