1978 - 1996 Big Bronco
disconnecting computer and vacuum hoses
Old Nov 25, 2006 | 07:27 PM
scroller bill's Avatar
scroller bill
Hi all. Ok, to start, when I aquired my 85 bronco with a 300il engine, it had headers, offenhauser intake manifold and holley 4brl carb. all the emissions components were not there and the computer was disconnedted. It ran fine.
I decided to put the stock exhaust/intake manifold and 1 brl carb back on the engine. I installed all emissions components I got from the junk yard, did not install an o2 sensor or catalytic converter. All the vacuum lines are connected where they are supposed to be. The carb is a carter yfa-1v feedback carb. I connected all the computer harness plugs to the proper components and connected the computer power and ground.
It idles rough and is blowing black smoke from the exhaust, I think this means that it is running rich. I tried disconnecting the computer and it made no difference in idle and black smoke.
Now finally, my question. Keeping this feedback carb, can I remove all vacuum hoses except charcoal canister hose to carb and brake booster hose and be able to remedy my running rich situation? Or does the feedback part of the carb need the computer for the carb to function properly?
The vacuum hoses will need to be reconnected for emissions(visual only here in pa) Would I be able to install a non feedback carb and still pass the visual emissions inspection?
Sorry for the long post. Any help would be greatly appreciated.
Bill
<!-- / message --><!-- sig -->
Bugzturbo
28
Jun 28, 2014 02:32 AM
briankoon14
Oct 17, 2012 03:49 PM
scroller bill
Nov 30, 2006 08:56 PM
scroller bill
Nov 29, 2006 12:59 AM
jasond5150
Sep 13, 2004 12:24 AM
