Sponsored by: Auxito
door locks
Old Nov 25, 2006 | 06:15 PM
shivelyt's Avatar
shivelyt
Cool door locks
My 99, F 150 door locks don't work right. It looks like they are trying to lock, but don't quite go down. Sometimes they will work when I put the truck in drive and sometimes not. There is no definite pattern. I'm not even sure where to start looking first. Anyone had a problem like this or have ant suggestions where to start? Thanks.
Old Nov 25, 2006 | 06:48 PM
Wilber15's Avatar
Wilber15
do you mean if you lock them manually or with the automatic locks? Check the voltage going to the motor. Compare it to battery voltage, is it the same? The lock motor could be wearing out. Also, if the door is infact locking, the rod that runs from the lock cylinder to the little *** on the door might have loosened up. You can manually tighten the rod by removing the door panel and sliding the rod on the lock cylinder connector i believe to tighten the connection up..
Old Nov 25, 2006 | 09:56 PM
HomerWinzlow's Avatar
HomerWinzlow
If they are like hundreds I have replaced on these trucks, they need just that... replaced.
Old Nov 26, 2006 | 04:04 AM
shivelyt's Avatar
shivelyt
Thanks for the info guys. It seems I can't keep up with replacing parts on this truck. With 105,000 miles, you would think they would last a little longer. My fingers would be sore if I typed in all the parts I have replaced. Thanks again.
Old Nov 26, 2006 | 05:24 AM
ajm859830's Avatar
ajm859830
Mine did the same. Replace the actuators and youre good to go....Im right along with you on all the parts replaced. I cant wait to get a new car.
Bubba Jones
1978 - 1996 Big Bronco
Mar 28, 2016 07:40 PM
Dale C
Dec 31, 2014 03:04 PM
berry1234
Escape & Escape Hybrid
Dec 11, 2013 11:48 AM
mikeinsequim
Feb 7, 2009 12:45 AM
cdrmotorsports
Dec 16, 2006 10:33 AM
