If this is the first time that you have ever pulled an engine be prepared to spend alot of time. I have never removed one but know that you have to have floor lift and a strong stand to attach it to when it (and the front stearing units and wheels etc come down.Dont attempt this without a service manual.
Jay, a.k.a. JTHill24 has a nice write up on how to pull a 3.0L engine out from the front. I did the same for my 4.0L and it's similar. Jay has a write up somewhere on the Web. You may have to wait until he provides the link.
There is no need to drop the engine through the bottom. That's too much work.
I ment to say "Why does my haynes manual say you got to remove it from the bottom" copper said the best way was from the front and I just wondered . Im all for the easy way
The Haynes and Chilton manuals all said you must remove it from the bottom.
Ford's service manual says you can do it either way. I followed Jay's instructions and pulled it out the front, very easily I might add.
Im happy to learn that replacing the engine can be done without a floor lift. Up to now this was the only repair I figured I would never be able to do.
