"c" motch question
Old Nov 24, 2006 | 07:11 PM
mechanicblue3's Avatar
mechanicblue3
"c" motch question
I am building a 48 f1 with a camero front clip. Need to "C" notch rear frame to provide more axle clearance. I have never even seen a "c" notch. So, any pictures and/or instructions would be appreciated.
Old Nov 24, 2006 | 10:45 PM
CharlieLed's Avatar
CharlieLed
http://www.classicperform.com/tech_a...-Notch-Kit.htm
Old Nov 25, 2006 | 06:32 AM
mechanicblue3
Thanks For The Help Charlielied
Old Nov 25, 2006 | 06:56 AM
bterry's Avatar
bterry
I did one on my son's '70 GMC. We used steel pipe and welded it in and boxed the frame. There's a couple of crappy pictures here (pgs 4-5 I think):
http://www.geosurface.com/c25buildup/Truck.asp
I'll have to find a picture of the finished notch.
Old Nov 25, 2006 | 01:12 PM
create's Avatar
create
i did the same thing bterry did.. here are some pics of mine.. This was before i cut the 2 inch overhang off the side and cleaned up the welds..
Old Nov 25, 2006 | 05:13 PM
mechanicblue3
thanks bterry and create. I could not find any pipe so I am bending some 3" X 1/4"
flat iron. will box frame. create - what truck is in your pitiures? It looks a lot like mine
(even the same jack stands) I'm asking because I don't know how much clearance I need.
Old Nov 25, 2006 | 05:26 PM
create's Avatar
create
my truck is a 55 F-100.. I was told you need atleast 3 inches of clearance between the rear end and the frame rails. This is with the back end weighted down..
the easiest way to measure it is to put the rear end on jack stands and add an equal amount of weight to the frame (whatever you have laying around) that will be about the same as your rear bed...
i just had a friend stand on it and i measured where i needed to put the c-notches.
Old Nov 25, 2006 | 05:34 PM
mechanicblue3
thanks again. i'll have someone stand on it.
Old Nov 25, 2006 | 05:51 PM
bterry's Avatar
bterry
Originally Posted by mechanicblue3
...will box frame...
Good deal, it's important. Mine ended up looking VERY similar to create's. His measurement should be good, if you like I could measure this one also.
The thing about using pipe is that you dont get 'stress risers' created at the corners of where you bend the plate. Might be worth a trip to a steel supplier to be sure.
Old Nov 25, 2006 | 06:28 PM
mechanicblue3
I think i'll wait until monday and get some pipe
Old Nov 25, 2006 | 06:41 PM
create's Avatar
create
yeah, i think i bought 4 inch diameter pipe... and only about 5 inches or so of it, cut it in half and there you go, you have two pieces to use.
it was pretty cheap if i remember, something like 5-7 bucks.
Old Nov 25, 2006 | 06:45 PM
keith56_cruz_cab's Avatar
keith56_cruz_cab
pic's in my gallery
Old Nov 25, 2006 | 07:41 PM
fatfenders56's Avatar
fatfenders56
I've said this before but it's a good idea to add a ''third rail'' in the center to reduce to the torsional strain
Old Nov 25, 2006 | 08:37 PM
imlowr2's Avatar
imlowr2
I see the purpose of the C notch and have done it on other vehicles. What are you guys doing for clearance to the bed wood? Without the 1.5" rubber snubbers on my frame, my rear end housing is smacking the floor of the bed. With a C notch, my rear end would probably go through the wood.
Old Nov 25, 2006 | 10:17 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
Do you have a picture of what you mean exactly. I do not have a cnotch but would like to store the info away for later use.
