Re-learing shift points?
Old Nov 24, 2006 | 10:29 AM
emmagator's Avatar
emmagator
I have a 2006 F350 completley stock. I recently put on a Donahoe leveling kit and 35" tires on my truck. Now the shifting kind of sucks, not real crisp. If I unhook batteries and allow the truck to re-learn its shifting with thses bigger tires, would this make a difference?
Thanks, DB
Old Nov 28, 2006 | 10:29 PM
emmagator's Avatar
emmagator
no one????
Old Nov 28, 2006 | 10:38 PM
NavyPowerstroker's Avatar
NavyPowerstroker
I think if you just drive it the way you normally would it will re learn on its own. It may take a little bit though. You may have to do some hard acceleration off the lines a few times and let it shift through the gears and it should learn.
Old Nov 29, 2006 | 07:14 PM
emmagator's Avatar
emmagator
Navypowerstroker, do u think it will ever feel the same as when i had stock tires, or will i always feel that loss of power??
Old Nov 29, 2006 | 07:22 PM
NavyPowerstroker
I have 35's on my truck and the shift is great. I don't notice any loss of power. I don't know that it will ever feel like it did stock but really I don't have anything to compare. I took my truck from the dealer to get the lift and tires so I don't remember what it was like stock. LOL.
Old Nov 29, 2006 | 08:18 PM
Kep4's Avatar
Kep4
Jäger
You may want to disconnect the batteries so the TorqShift can relearn with the new set up. Go into the 6.0 Tech Folder at the top of this forum, look for "TorqShift shift relearning strategy", it's about 15 to 20 links from the top. Hopefully that will help you out.
Old Nov 29, 2006 | 09:35 PM
ford4lifer's Avatar
ford4lifer
home.austin.rr.com/sbv1/Procedures/TorqushiftShiftRelearningStrategy.htm
That should be it.
Old Nov 30, 2006 | 08:34 PM
emmagator's Avatar
emmagator
thanks guys i will try the relearn strategy.
Old Dec 2, 2006 | 09:38 PM
cawatters's Avatar
cawatters
Try an Edge...
The Edge seems to help with the shift points whaen you make the modifications to the suspension and tires....
cjben
15
Dec 6, 2016 07:18 PM
Ddaybc
Jun 1, 2013 10:02 PM
Mudsling3r
Oct 23, 2009 12:54 PM
bulletsneverlie
Apr 5, 2009 06:54 AM
Phantom
Jul 16, 2004 05:02 PM
