Noise from dash when starting.
Old Nov 24, 2006 | 08:36 AM
krazymatt's Avatar
krazymatt
I have a brand new 2006 F-150 SC 4x4 Lariat, and when I start it, there's a strange noise coming from like inside the dash. Is this normal? Sounds like a mechanical noise kinda like an actuator or something, and lasts about 5-10 seconds. I'd appreciate anyone share any simalar experiences. Thanks
Old Nov 24, 2006 | 08:58 AM
EnergizerBunny69's Avatar
EnergizerBunny69
Can you be more specific in describing the noise. Is it the fuel pump cycling that you are hearing? Try to be MORE specific.
Old Nov 24, 2006 | 09:37 AM
krazymatt's Avatar
krazymatt
It literally sounds like it's coming from behind the instrument panel or the radio. There's no way it could be the fuel pump in my opinion. It almost sounds like it could be something to do with the climate control system or something. My wife thinks it's the adjustable pedals, could it?
dbrown13's Avatar
dbrown13
Same problem herem sounds like an actuator door
Old Nov 24, 2006 | 09:41 AM
krazymatt's Avatar
krazymatt
dbrown13, exactly! It sounds like a squeaky actuator door. Is it normal or can it be a problem?
Old Nov 24, 2006 | 09:48 AM
krazymatt's Avatar
krazymatt
Also, it happens when the truck has been off a while. If I try and shut it off and start it imediately to try and duplicate the noise, it won't do it.
Old Nov 24, 2006 | 09:58 AM
dbrown13's Avatar
dbrown13
I'll bet you also have the electronic climate control system. if so, try changing the temp from hot->cold or cold->hot and see if you can duplicate the problem. I plan to contact my Ford dealer to inquire about the problem.
Old Nov 24, 2006 | 10:05 AM
krazymatt's Avatar
krazymatt
Yes, I do have the climate control. Last night I turned off the climate control, to see if it does it next time I start the truck. I guess it could be normal as long as everything works. I've heard other strange noises coming from climate controls of other vehicles.
Old Nov 24, 2006 | 12:47 PM
captchas's Avatar
captchas
Guest
it's normal. it comes from the air control door of the heating system when the vacume pulls it back to the setting it was on.
Old Nov 24, 2006 | 04:25 PM
l-m tech's Avatar
l-m tech
Open Up The Glove Compartment,with The Engine Off,turn The Ac System On And You Should Be Able To Pinpoint The Noise.its Coming From The Fresh Air Door Motor Pivot Arm.i Used A Q Tip With Some Light Weight Grease And A Long Pair Of Needle Nose Pliyers.get The Grease To Go In The Gate Of The Arm And Turn The Ac System Off And On A Couple Of Times And It Should Take Care Of The Noise.for How Long I Dont Know But It Beats A Trip To The Dealer.
Old Nov 24, 2006 | 08:52 PM
krazymatt's Avatar
krazymatt
Thanks guys! I will attempt the q tip with the grease. I'm sure 9 times out of 10 the dealer service guy will say it's normal anyway. You're talking like silicone grease right? Thanks again.
Old Nov 24, 2006 | 11:37 PM
EnergizerBunny69
I had to go back outside and check my truck and then talk to a buddy of mine about it. He told me that it was in fact the actuator for the door for the fresh air on the a/c system.
Old Nov 25, 2006 | 10:23 AM
HomerWinzlow's Avatar
HomerWinzlow
The door resets itself to fresh each time you shut down, which is why you notice it on startup. It is electronic, not vacuum.
Old Feb 1, 2007 | 06:32 AM
pepperjr's Avatar
pepperjr
My 06 Lariet does the same thing. It has the auto climate. I will try the q tip thing and get some relief from that noise. Thanks
sumbuddyloanmea.10
Feb 4, 2022 10:04 AM
EatBeef
Mar 5, 2011 10:10 AM
Buck60
General Diesel Discussion
Sep 23, 2010 09:52 AM
jekstrom86
1983 - 2012 Ranger & B-Series
Jan 11, 2010 10:46 PM
NDrum2005
2004 - 2008 F150
Jul 18, 2007 09:47 PM
