Camber problem
Old Nov 22, 2006 | 11:46 PM
mms2k5's Avatar
mms2k5
Unhappy Camber problem
I have a 72 2WD F350. I lower it by using f250 coil springs in front and removing a couple of leaf spring in the back. The drop was about 3". The problem that I now have is that the camber needs to be adjusted and when I took the truck in to have it align, it does not have a camber adjuster. Does anybody know of a kit or tubular A-arm with camber adjuster?
Old Nov 23, 2006 | 02:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
It must be riding on the frame in front. Put the proper springs back in, sell it and buy a F150.
Old Nov 23, 2006 | 04:59 AM
jowilker's Avatar
jowilker
mms2k5 Welcome to FTE The nations truck stop.
Sounds like you have done the No no to the front end. I'm sure there has been someone that has been sucessful lowering the front end without it, but AFAIK the only way to properly lower one is with drop spindle axles.
Hopefully someone that has done it will stop in and can advise.
John
Old Nov 23, 2006 | 08:45 PM
mms2k5's Avatar
mms2k5
Oooooohps!
Old Nov 26, 2006 | 07:58 AM
Red69's Avatar
Red69
The only adjustment for camber is to bend the I-beams. Not many front end shops can do this.
Old Nov 27, 2006 | 01:39 AM
mms2k5's Avatar
mms2k5
Thanks for your input you'all.
