I have a 72 2WD F350. I lower it by using f250 coil springs in front and removing a couple of leaf spring in the back. The drop was about 3". The problem that I now have is that the camber needs to be adjusted and when I took the truck in to have it align, it does not have a camber adjuster. Does anybody know of a kit or tubular A-arm with camber adjuster?
Sounds like you have done the No no to the front end. I'm sure there has been someone that has been sucessful lowering the front end without it, but AFAIK the only way to properly lower one is with drop spindle axles.
Hopefully someone that has done it will stop in and can advise.
