Stearing Wheel Removal?
Old May 23, 2002 | 12:29 AM
soso's Avatar
soso
Old May 23, 2002 | 02:58 PM
58_f100_4x4's Avatar
58_f100_4x4
I am trying to get to the turn signal switch and can not find a way to get the stearing wheel off? I have pulled off the nut on top under the horn button and have pulled like crazy nothing is happening. Is there some trick or how does this think come off.
This is on a 1958 F-100 with the stock stearing box.
Thanks,
Erik
Old May 23, 2002 | 04:45 PM
angus's Avatar
angus
You probably need a steering wheel puller, which has two bolts which screw into the hub of the steering wheel, and another that pushes down on the shaft, if I remember correctly. (haven't used it in a long time. I'm assuming you've removed the horn button, horn contact thingummy, and the nut that holds the wheel to the shaft.
[59 merc m100 "rust leper II", 60 merc m100 "blair witch truck", 60 ford panel]
Old May 23, 2002 | 08:48 PM
barry's Avatar
barry
Make sure when you use that steering wheel puller to leave the nut on the shaft just flush with the top of the shaft, so you don't mess the threads up.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
