1978 - 1996 Big Bronco
pulsating engine
Old Nov 22, 2006 | 06:59 PM
96eddie5.8's Avatar
96eddie5.8
pulsating engine
heres the deal. becuase the truck was having a hard time starting when cold, i replaced the distributor cap and rotor (which both had some corosion), as well as checked the plugs and IAC. So far this week, no more hard starts, but now the engine pulsates while running hot. during idle a pattern of pulsates can be recognized. when driving under highway speeds, another pattern of pulses can be detected but it is sparatic. often the pulsating shakes the steering column, and a passanger even could feel the shaking.
i have checked to make sure that the wires to the plugs are in the right order. the first time i noticed this was after i removed a plug to check it, and replaced it, and befor i replaced the distributor cap.
thanks
Old Nov 24, 2006 | 06:59 AM
helirich's Avatar
helirich
Its probubly a wire or plug. Just let it idle and pull off one wire at a time. If it runs worse, put it back on. The one that doesnt change anything is bad. (the wire or plug)
Old Nov 24, 2006 | 07:19 AM
96eddie5.8's Avatar
96eddie5.8
thanks, great advice
Old Dec 3, 2006 | 07:06 PM
nickmobile67's Avatar
nickmobile67
Keep us posted. My '86 does that idle thing, where you see the tach needle move up and down about 100 rpm. Don't notice driving though, it smooths out when you give it a little gas, but bumping the idle up didn't help. Neither did cap, rotor, plugs, wires, coil, ect...
Old Dec 4, 2006 | 03:20 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Try checking that specific plug wire. I'll bet a terminal was pulled loose, or maybe the conductor cracked or separated.
Old Dec 4, 2006 | 06:36 PM
96eddie5.8's Avatar
96eddie5.8
if its the wire can you buy just one wire?how much are we looking at for that?or for all new wire?
the wires are new from a year and a half ago, same with the plugs, but the plugs look great.
Old Dec 8, 2006 | 10:00 PM
Black Ford XLT's Avatar
Black Ford XLT
96 u can also try reading the codes may be other problems TR
Old Dec 12, 2006 | 08:07 PM
96eddie5.8's Avatar
96eddie5.8
well i bought new wires, and just had time to install the one that i thought might be broke. well its still doing it. and to make a correction its not so much of a shivering type vibration, which periodicaly is bad enough to shake the truck and stearing column. as soon as i get home, im going to change out the rest of the wires and check that one plug again. so well just have to see
Old Dec 16, 2006 | 04:39 PM
96eddie5.8's Avatar
96eddie5.8
i guess hairline crack in plug in cylinder 5 has gotten bigger in the last few weeks and finally got registered in the codes two days ago. cylinder 5 misfire. changed it out today and its funning perfectly now
Old Dec 16, 2006 | 09:45 PM
thelonerangerxlt
Glad you found it 96Eddie. Gotta love those easy fixes......
Old Dec 17, 2006 | 11:31 AM
96eddie5.8's Avatar
96eddie5.8
yeah, 1.50$ is the best kind of fix! the only question that i have now, is that the idle speed is higher now, both out of gear and in gear, then before. could i have bumped something in the engine compartment, or would this just be a result of the new plug wires i installed along with the new plug? should i lower it back down to around 700, its at about 10-1100 right now
footballa
2004 - 2008 F150
Aug 31, 2016 01:40 PM
fairlane70
Aug 10, 2013 06:28 PM
mikulskn
Jun 26, 2013 11:23 PM
JoeBlow
17
Nov 4, 2005 04:33 PM
