1978 - 1996 Big Bronco
Help, with fuel pump issue?
Old Dec 8, 2006 | 04:21 PM
icantdo55's Avatar
icantdo55
Last night in the cold (30*) I tried to start the Bronco it stumbled and than would just crank. I do not hear the fuel pump running when key is cycled on and off. Where do I start? Checked the shrader valve (sp?) on the fuel line and there was no pressure in it.
Would rather not drop the tank first to find out the problem was somewhere else.
Where is the fuel pump relay and how do I check it?
From the wiring diagram there is not fuse right. Just a fuseable link....whitch one?
Any help would be great....whats the common problem.
Thanks
-Mike
1991 Bronco 302 AT
Old Dec 8, 2006 | 05:45 PM
bobstrat's Avatar
bobstrat
fuel pump relay should be on the drivers side inner fender. haynes manual will tell you how to test it.
could just run a jumper to the fuel pump.
Old Dec 17, 2006 | 02:12 PM
RedRooster77's Avatar
RedRooster77
There is also an inertia switch in case of an accident in the cab passenger side floor panel. I would guess its your fuel pump.
Old Dec 17, 2006 | 04:19 PM
icantdo55's Avatar
icantdo55
It was the pump. Replaced it and it works fine now. 177,000 miles RIP.
