Oil Change
Old Nov 22, 2006 | 05:35 PM
jreilly57's Avatar
jreilly57
Oil Change
I had a question regarding oil changes on a '48 F-1. After all the oil is drained out, I open the oil filter cannister to remove the filter and there is still considerable oil in there. I have to use a little suction pump to draw it all out. Is this normal?
Old Nov 22, 2006 | 05:51 PM
packrat56's Avatar
packrat56
I don't know the early Ford canisters, but it sounds like some other old ones I have had. Turkey baster time....
Old Nov 22, 2006 | 06:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The flow of oil thru the canister is from outside of the element to the inside, thru holes in the center tube, down and out the bottom. The holes in the center tube aren't all the way at the bottom, so you will have an inch or so (as I recall) when you open it. Some Merc filters and aftermarket filters had a drain valve on the side to completely drain them.
Old Nov 22, 2006 | 09:31 PM
48ATOY's Avatar
48ATOY
on my 48 with 226 six
there is a drain plug on the bottom of the oil filter holder
the first time that I drain the oil there was alot of sludge in the drain hole
nobody for the last few years never drained it he right way
Joe
Old Nov 23, 2006 | 09:55 AM
F6Guy's Avatar
F6Guy
As stated earlier that is normal. the hole in the tube is not at the very bottom. in all honesty you probly could do without the filter as it doesnot do a whole lot. I am planning on purchasing a full flow filter kit from motorcity flathead and will be getting rid of the original.
Old Nov 23, 2006 | 12:21 PM
jreilly57's Avatar
jreilly57
Does Motor City Flathead have a parts web site where you can get more info on the full flow filter kit? I didn't have much luck finding any information on it.
Old Nov 23, 2006 | 02:37 PM
Fomoko1's Avatar
Fomoko1
[ F6Guy I am planning on purchasing a full flow filter kit from motorcity flathead and will be getting rid of the original.]
Is there a kit to go to a full flow that`s with a spin on filter out there?
That would solve both problems.
Old Nov 23, 2006 | 05:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
For the flat V8, you should go here:
http://www.btc-bci.com/~billben/flathead.htm
and read about the alternatives.
The bypass style filter does a lot of good; it just won't prevent a piece of dirt from going directly to the main bearings (always). In fact bypass filters are back in vogue to extend oil change intervals. They are a much finer filter media than the spin-ons (especially Fram).
The MCF "full-flow" set-up is a major pain to install, won't work with certain pans (like if your pan has the three ribs on the sides), and I have heard mixed opinions on whether or not it's worth the trouble. If you have a Canadian block, or have your block out of the truck, there is an alternative "95%" setup that is bulletproof and actually very similar to the stock Chev 350 setup. It requires drilling a hole at the back of the block and inserting a plug to divert oil out of the block and then back in (see pic). The Canadian blocks already have the extra hole. I believe this setup is also described on the page (above). [Note: the drawing is by the guy who sells the plugs used to divert the oil; I encourage you to patronize him if you go this way!]
Old Nov 23, 2006 | 05:34 PM
51dueller's Avatar
51dueller
Here's a pic of the cdn full filter assembly. It was only like used from 48-49 on the Mercury cars.
Old Nov 23, 2006 | 07:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I've never seen that Dueller! In fact I didn't know they even used the drillings for a filter, I thought it was for an extra gauge or something. As far as I know, they all ('48 - on) had the drillings, right? (even if they didn't use them)
How did those Mercs force the oil thru the filter, did they have a piece like in my picture? It would seem like if they didn't, you would HAVE to run a full-flow on those engines, or at least connect the two fittings with a hose.
Old Nov 23, 2006 | 08:25 PM
51dueller's Avatar
51dueller
Yes the 48-54 Canadian blocks had the extra fittings. I think they had a similar plug like you since you can see that the oil pressure sender is mounted on top of the filter assembly. I don't know much about the system since I've never seen one. I found this picture of the MSN flathead V-8 forum years ago and kept it since I was trying to find a good flathead at the time. I don't even think you could find a filter for it anyway.
Old Nov 26, 2006 | 08:52 AM
F6Guy's Avatar
F6Guy
Those are both neat alternatives. I too was unaware that merc offered a filter like that. Iw ill do some more research before I make a purchase. The MCF kit looks easy to install once the motor is out the vehicle. I belive Speedway Motors sells the kits.
aspenedgermk
1983 - 2012 Ranger & B-Series
Jan 12, 2011 01:29 AM
Corner Gas
Sep 25, 2010 09:53 PM
Wagion
Modular V10 (6.8l)
13
Jul 19, 2010 09:21 PM
surfpunk
31
Jan 2, 2005 02:18 PM
JohnAW
Oil & Lubrication
31
Sep 18, 2004 10:52 AM
