92 idi keeps stalling at stops
Old 11-22-2006, 01:10 PM
mackdog's Avatar
mackdog
mackdog is offline
Question 92 idi keeps stalling at stops
my 1992 f 250 7.3 idi likes to stall out when the rpms drop suddenly, ie: at a stop sign. I replaced all the o rings on the injector return lines and the problem still exists. It seems to run great, even on cold mornings. So I dont think its an injector pump problem. I think it might be a fuel shut off solenoid or a timing advance solenoid.....? does anyone have any ideas..?
Old 11-22-2006, 03:21 PM
roamer37's Avatar
roamer37
roamer37 is offline
What is the Idle speed set at is it a auto or man trans?
Old 11-22-2006, 04:15 PM
mackdog's Avatar
mackdog
mackdog is offline
it is a manual...im not sure what the idle speed is, my tach does not work....it has to be something with the fuel shut off because when it stalls it sounds like someone turned the key off......i mean there is no sputtering or anything
Old 11-22-2006, 06:10 PM
PLC7.3's Avatar
PLC7.3
PLC7.3 is offline
Mackdog..email me and I will send you a TSB re your problem. Just click on my name and use........ SUBJECT: IP TSB
Old 11-22-2006, 09:05 PM
Kleenax's Avatar
Kleenax
Kleenax is offline
I also have a 92, and it too was stalling when I would suddenly take my foot off the accelerator. It had been sitting for awhile, so someone suggested I merely dose the fuel with a good fuel additive since the IP just might be gummed up a bit. I put a whole bottle of diesel additive in the next tank-ful, and ran that on a trip, and it's never done it again!
The suggestion was to also change the fuel filter, and (also) fill the new filter with fuel additive when you install it. Couldn't do that at the time, but the super-dose of additive seemed to do the job just fine.
Ray
1992 2WD F-250 7.3L 5-spd - new Jasper longblock, Bought from local University (MSU - 09/20/06). Completely stock as far as I can see - I'm a new owner LOTS of new parts on her- 163,829 miles as of yesterday. Now on to tackling Biodiesel!!
Old 11-22-2006, 09:15 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
This new ULSD has a cleaning effect on fuel systems. If you have had a bad batch of fuel at one time and some sediment was in your fuel tank. Then there is a good possiblity that all the sediment went into the filter and either partically or fully plugging the fuel filter.
Old 11-28-2006, 12:47 PM
mackdog's Avatar
mackdog
mackdog is offline
Thanks guys....I think the fuel filter was the problem...it seems to run fine now.
rednekrebel28
41
03-30-2023 08:28 AM
rowdyredneck
04-11-2017 12:18 PM
rowdyredneck
04-09-2017 07:42 PM
jdemaris
05-17-2016 10:06 PM
Motosk813
01-20-2016 04:45 AM
Quick Reply: 92 idi keeps stalling at stops
